Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Help for carb istallation needed!
Old Apr 26, 2008 | 03:19 PM
James911's Avatar
Default Help for carb istallation needed!
Hi,
I bought an disassembled Impala (350 cui, 1970), therefore I have some problems to put it together.
I also struggle a little bit with my carb, an edelbrock 1406, 600 cmf.
http://i303.photobucket.com/albums/n...gine/carb1.jpg
No 1 comes from the transmission.
Where do I have to fix No. 1? Where the arrow goes?
Where do I have to put No. 3 of the cable no 1?
Is No 2 at the correct place? Is it fixed correctly (no4?)?
Do I need a spring somewhere?
Some more pics:
http://i303.photobucket.com/albums/n...gine/carb4.jpg
http://i303.photobucket.com/albums/n...gine/carb3.jpg
http://i303.photobucket.com/albums/n...gine/carb2.jpg
Thanks a lot
James
Old Apr 26, 2008 | 04:33 PM
9000th01ss's Avatar
The top cable is the throttle cable you need a return spring somewhere.
The bottom cable is the trans cable, there were several brackets and cable combinations used. It looks like you need the one that bolts to the two rear intake bolts.
Then to adjust it, it should reach full pull at WOT.
