need help with alt. mounting
The 350 has a big bracket for the smog pump and the a/c compressor but im not using either of them so that side of the engine would be open, and the bottom bolt hole on the other side is semi-blocked by the water pump.
The T/A has a multi ribbed belt right? nothing rides on the smooth side of the belt?
The truck water pump is designed for counter clockwise operation since it had a serpentine belt, it had a smooth water pump pulley and it rides on the smooth side of the belt.
If you're using the T/A pullies you need the T/A Clockwise pump. This pump should have the right mounts also.
They eliminated a lot of the mounting points on a CCW pump because they are not needed and it prevents installation on the wrong application.
If you just get the T/A water pump you should have not one problem with all the original T/A brackets.
FWIW everything on the truck turns CW except for the water pump, and the water pump flows water the same direction as the T/A's even though it turns CCW.
