LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Small Block & Big Block Chevy Specific (https://ls1tech.com/forums/small-block-big-block-chevy-specific-92/)
-   -   small block guru's inside (https://ls1tech.com/forums/small-block-big-block-chevy-specific/940253-small-block-gurus-inside.html)
sdimer350 Jun 18, 2008 07:27 PM
built a 355 for my s10. seems like a turd. 10-1 bottom end, world sportsman 2 heads, sportsman intake, 750 edelbrock, cam specs as follows- comp
Duration Advertised: 274° Intake / 286° Exhaust
Duration @ .050'' Lift: 230° Intake / 236° Exhaust
Valve Lift w/1.5 Rockers: .490'' Intake / .490'' Exhaust
Lobe Separation Angle: 110°
has headers and all the other stuff. can anyone see anything wrong with this combo? gunna try a holly carb. advance or retard the cam? any pointers greatly appreciated.
slow95z Jun 18, 2008 07:38 PM
definitely change carbs. edlebrocks suck big time. hows the timing set now? with the specs you gave the truck should have trouble keeping tires on it.
kenSS Jun 18, 2008 07:56 PM
yeah def. put a holley on it. sounds like a decent combo for a killer street motor.
sdimer350 Jun 18, 2008 08:37 PM
tires and rearends! twisted an axle off at the splines:D weak ass 10 bolt caused me some body work:bang:. im gunna go 8.8 outa a exploder. i will try holly and report back thanks guys.
ZONES89RS Jun 18, 2008 08:55 PM
Well, a 10 bolt 8.5 might be an easier swap srom another vehicle? But, it should run great, from the lift it looks like a flat tappet, if it was not broken in with the proper oil and springs, it can make a great cam idle like stock and eventually start backfiring.
82 camaro Jun 18, 2008 09:00 PM
The 8.8 is a very easy swap for these trucks with a 3.73 gear and a 3500 converter it will be a great street rod..
9000th01ss Jun 18, 2008 10:07 PM
Whats listed looks ok but what about trans and converter? Exhaust size.
The edelbrock probably needs to be tuned, I had one on my S10 that was jetted on the lean side in stock form, when I got it right it was still a POS as far as reliability.
I also put a 8.8 with redrilled axles in mine, it's 3" wider than stock, so be sure your wheels will still fit right.
LS1 Coupe Jun 19, 2008 06:25 AM
There are a few things that come into play, gears will cause a deffinate inmpact on performance, the other is your configuration, Sportsman heads come with diiferent size chambers, and also have a 200cc runners, not real good for a 350 street machine, they would probally work best for topend and a single plane intake, the SR tourquer heads would have been a better solution, you also mention you have 10.1 lower end, are these the flat top 10.1 pistons w/64cc heads? if so and the chamber volume is 72cc your compression is about 9.2cr. The cam although will run in a 350 deffinately needs CR with the 230/236@.050 and probally runs best wide open throttle, cruising and jumping on it might be a bit doggie, The comp XE268 might have been a better choice. That cam is a nice cam in a 383 running around 10.1-10.5cr. I ran a roller 230/230@.050 in a 350 w/10.1cr and it was fun only when it was wide open throttle, it sucked big time on the highway and jumping on it with out having to downshift 2 gears and with 3.73 gearing. Also note, that head would also work well on a 383.
jmm98LS1 Jun 19, 2008 08:45 AM
There's nothing wrong with your edelbrock carb except the size.....a 750 is way too big for what you have unless you're spinning it to 7000rpm. You'd be better off with a 600-650cfm carb, and regardless of what carb you use it's absolutely going to need tuned to run properly. The 750 edelbrock I have on my 383 was uber rich right out of the box.
sdimer350 Jun 21, 2008 11:52 AM
has a built 700r4, 3000 stall, 2.25" exaust that i am upgrading to 2.5 or 3, 3.73 gears. also, this is going to be a drag truck so streetability means dick, and it will be turned at 6500-6800 rpm.
9000th01ss Jun 21, 2008 12:46 PM
Originally Posted by sdimer350 (Post 9599295)
also, this is going to be a drag truck so streetability means dick.
I don't know where that comes from, maybe because I said edelbrocks aren't good for reliability.
You need a reliable carb. Drag only, great what if your non reliable carb starts shitting gas as your staging? You get pushed backwards off the track.
WickEdSix98 Jun 21, 2008 01:14 PM
I'd rather have a Holley but the Edelbrock's can be tuned to work great also. For the best performance, don't expect to just bolt a carburetor on and not have any fine tuning to do.
WheelsUp84z Jun 22, 2008 04:05 PM
if its a drag car, put more gear, bigger tire and higher stall. More cam wouldnt hurt either. You're probably going to want to ditch that 700 in favor of a th350 too.
jersyboyy Jun 22, 2008 10:32 PM
Th400s are bullet proof but weigh a little more than the th350 but imo worth it if its a strip car. Ditch the edlebrock and get a 660 holly similar, make sure to have it tuned after everything is broken in too.
Read up on stalls, 3000 stall is good for what you got but bigger stall and bigger cam and a properly tuned carb will make it run alot quicker. O add a few horses with some 1.6 rockers and make sure you get enough fuel, if your running stock pump might want to consider that too.
92builtbird Jul 8, 2008 09:08 PM
My 350 turbo is pratically bulletproof. Weighs less, shifts faster, and it doesn't lose as much rwhp. A Th400 is just too much for a 355. Just my opinion though.
slow and da curious Jul 8, 2008 09:40 PM
Good friend of mine did a similar build to yours using a brand new Edelbrock carb. He had the carb on for about 6 months, ran ok, idled fine, didn't bog or anything. He just thought his combo should've been faster than it was running. He borrows another racers identical size Holley, bolts it on and picks up 3 tenths on the first pass. I'm not a carb genius by any means but I've always heard that Edelbrock is a good street carb but if you're gonna race it, buy a Holley.
Personally, I ran a 750 Race Demon. Beautiful carb first of all (if a carb can be described as that...lol). Motor was a 14-1 383, Brodix heads, blah, blah, blah. Never had an ounce of trouble with the Demon though.
edcmat-l1 Jul 8, 2008 09:57 PM
If its drag only, why only 10.1:1?
It should have more compression, by a bunch. more camshaft, more converter, more gear, more tire, etc.
This is one of those totally wrong combos, and then people wonder why they run like shit.
A 350 in a truck is going to be a dog, plain and simple. Bail on it now, and save yourself the headache.
If you're set on keeping it, pull it all apart and do the necessary machine work to get the compression as high as you possibly can. Swap the cam for a nasty roller, and the carb and intake for a single plane 700 cfm holley, and put a 4000+ converter in it. Then it might run 1/2 way decent.
JakeFusion Jul 8, 2008 10:56 PM
What is the purpose of the truck? If it's drag, then you went wrong all the way around...
If it's a street machine, your combo isn't awful, but it's not even close to being optimized. Your biggest problem (motor-wise) is the compression and the heads. Ditch them and go Brodix IK, AFR Eliminator, or Dart Pro-1 Platinum. Anything in the 180-200cc range will work fine.
If you really want to spin it up though and have good drivability, lightweight LS1 gear like that on the AFRs can help you turn better RPMs out of a hydraulic roller. If you have an pre-86 block, then going hydraulic is expensive and not always the best choice. Going to a solid roller, however, would be good if you chose a street grind like the Comp XE or Lunati Voodoo to give you the best of both worlds (street/strip) with just a little added precautionary inspections to the valvetrain when you change the oil.
99T/A Jul 9, 2008 10:21 PM
IMHO change the carb from the get go. Secondly you have a nice setup for a street truck, but if it is drag only then why hold so much back. I have a 84 S-10 I am finishing right now. 355, 12.87:1 domes that are .005" out of the hole. 215cc Dart Iron Eagles w/ 64cc chamber. Ports, bowls, and chambers have been cleaned up and polished, 264/270, 679/645 lift solid roller, port matched Victor Jr with a 980 Da Vinci Holley. I am fixing to put two bottles on it and see where it goes. I am also running a fully built 1.76 Glide with trans brake and a 4400 stall with 4.11's. Oddly enough this truck will be driven to street meets on the weekends:chug:
edcmat-l1 Jul 9, 2008 10:44 PM
Thats a little more like it. Only thing I would have done differently is stroke it. 383 or 396. No replacement for displacement. I hate small motors. Other than that, sounds like a pretty solid combo.
One more thing. With a SB, you may wanna re consider the glide. Unless its a lightweight truck. A 3 speed anything will probably run better for that set up.
© 2026 MH Sub I, LLC dba Internet Brands
