Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Edelbrock Heads
Old Jul 20, 2008 | 12:11 PM
monzter's Avatar
Default Edelbrock Heads
Are Edelbrock Performer Rpm heads any good in hi rpm 355, around 8000 rpm with proper cam (SR) and Weiand tunnel ram with 600x2 ?
best regards.
Old Jul 20, 2008 | 12:29 PM
9000th01ss's Avatar
No, not IMO.
Not with 1200 cfm of carbs going up to 8000 rpm.
Old Jul 22, 2008 | 03:05 PM
shaolink9's Avatar
they will probally be a little to mild for what you are tryin to acomplish
Old Jul 23, 2008 | 04:42 PM
MrOverkill's Avatar
Too small to rev that high, 170cc I think? You need some compression, at least a 200cc runner and a large by huge solid roller to pull that off.
Those heads are DONE at 6500 on a 350 mill, I had a 355 12.5:1 JE/Carrillo, .680"/272* mech roller with 221cc Brodix Track Ones an out of the box 950HP holley that would spin 8000+. That little sucker woulld pull all the way from 5000-8500 it made 433whp N/A through a very loose 5000rpm converter. Went easy mid 10's in a 3100lb 69 Camaro small tire car....
In short BIGGER HEADS are needed to meet your goals....
