Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
P/S pump
Old Aug 21, 2008 | 01:45 PM
UpOnOne781's Avatar
Default P/S pump
Hey does ne 1 kno if i can replace a type II PS pump in a Z28 to a saginaw style like on a third gen? And if i can how do i plumb the old lines into the new pump?
Old Aug 21, 2008 | 08:48 PM
Drumer919's Avatar
What year z are you talking about?
Old Aug 22, 2008 | 12:33 PM
UpOnOne781's Avatar
I got a 95 but im not using an LT1. Im putting in a first gen and cant find any accessory setups that might work for me. Any ideas if the pump will work?
Old Aug 23, 2008 | 10:41 PM
Drumer919's Avatar
Why not use the factory pump?
Old Aug 24, 2008 | 08:21 PM
UpOnOne781's Avatar
idk if my stock PS pump will fit on the brackets i have...but im gunna find out when i go to put it on
Old Aug 25, 2008 | 09:32 PM
Drumer919's Avatar
I'm using a bracket I picked up at jegs, just a really simple stamped steal bracket, got it for like $20, before that though I was using a old style bracket I found in a junk yard, my 94 V6 pump fit both, it took a small amount of grinding on the junk yard bracket but it fit the new bracket with no modification.
If for some reason you do have to end up using a different pump and the lines dont connect take the lines from what ever pump you use and the lines from your rack and find machine shop and they will be able to make lines for you
Old Aug 26, 2008 | 01:02 PM
UpOnOne781's Avatar
alright thanks for the help...i just got a serpentine setup from summit that has everything...i hope it works out, we will soon find out
