Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
mild 307 with weiand 142
Old Aug 24, 2008 | 09:33 AM
nastychevelle's Avatar
Default mild 307 with weiand 142
i plan on adding a weiand 142 to my mildly built 307 (specs below) but i have a few questions first
how much boost could i run with my setup safely (i planned on running small pulley ratios like 1.95:1 or 2.11:1)
would i need to change carbs or do any mods
would this make decent torque on my motor
i know its not going to fit under my SS hood.... is it gonna fit under a 4" cowl?
fresh rebuild
882 heads
crane 274h cam
torker II intake
holley 650
longtube headers
Old Aug 24, 2008 | 12:49 PM
TurboAv's Avatar
What compression ratio are you at? Could you post the cam specs? A double pumper carb works better on a roots application. My old motor in my Impala was a 377 stroker with a 850 double pumper, Weiand 177 blower. I built that motor at 9:1 compression and ran 7 psi.
Old Aug 24, 2008 | 01:50 PM
idk exactly what compression im at but i know its low desktop dyno said around 9:1 but i think its lower due to the small bore and big chambers but the cam specs are .450/.450 and 218dur at .50 i cant remember the LSA
