Install question on a 12 bolt
DR
a "standard" 12bolt does NOT have any place to attach a torque arm to.
so you'll need to:
fabricate some form of torque arm mount.
fabricate teh rear spring perches, shock mounts, LCA mounts, and panhard mounts
narrow the rear end
put in new housing ends to match your brake setup... id reccomend C-clip eliminator style ones....
its ALOT of work... and its the exact same work needed to put any non-fbody rear under our cars... doesnt matter if its 12bolt, dana44, 9", GM, ford, or mopar....
