Southern Members A regional forum for all our down South members.
need help with my 98 camaro
Old Jan 14, 2006 | 01:45 PM
StrokerLS1's Avatar
Default need help with my 98 camaro
can anyone remove the speed limiter on my 98 camaro. its a 6 speed but somehow it will cut out at the top of 4th which is about 110-115mph. i live northeast of atlanta in lawrenceville. thanks Brian
Old Jan 14, 2006 | 02:28 PM
slt200mph's Avatar
That is becasue your car when it came from the factory had the cheepest lowest speed rated tires on it..mine was the same way..wouldn't run over 118 MPH... I had mine edited out using LS1 edit..
Old Jan 14, 2006 | 06:34 PM
StrokerLS1's Avatar
man that sucks. why would chevy put such cheap *** tires on to were they have to put a speed limiter on the car.
Old Jan 14, 2006 | 10:57 PM
Out1aw's Avatar
Find someone with the HP Tuners for it. That removes it I believe. Or do what Steve said and use the LS1edit.
Old Jan 15, 2006 | 09:45 AM
slt200mph's Avatar
So that if some moron was out driving 140 MPH and a tire let go and got himself or someone else killed they would have no liability issues to deal with..when you are a OEM you have to deal with theat kind of ****...V8 F body cars will run way past 118 MPH in stock configuration..higher speed rated tires were available and those cars that came equipted with them did not have speed limiters set that low..beleive it or not some people do not drive these cars as fast as they will go.
Old Jan 15, 2006 | 01:56 PM
StrokerLS1's Avatar
yea i took my bone stock 99z to 150 racing a my bros stang. it was quite the rush
