Southern Members A regional forum for all our down South members.
expert LS1 Tech. in central NC needed
Old Aug 3, 2006 | 11:52 PM
JonCR96Z's Avatar
Does it do it at the same rpm in every gear? Will it do it if your rolling (at a speed where it would normally happen) then put the car in neutral and raise the rpms? How long has it been doing it? Did you change anything around the time when you first noticed it?
Also doesn't a broke tranny mount sound like the tranny is gonna come through the floor during a shift?
Old Aug 4, 2006 | 09:31 AM
00 YEAH's Avatar
i was also thinking flywheel bolts, but if its only at a certain RPM, i dontthink they would fall under that category. i think it would be all the time.
Old Aug 4, 2006 | 11:23 AM
jlashley2001ss's Avatar
well it happens at the same rpms in every gear. At 1000 rpms my rattle/vibration in the car is really getting on my nerves. I had a mechanic to check the bolts to LCA's and PHB and he said everything was tight. I dont know whats up? I dont think this would be coming from exhaust would it??? My hooker catback is quiet and exhaust drone is out of the question i would think
Old Aug 4, 2006 | 12:23 PM
JonCR96Z's Avatar
Well if its the same rpm in every gear then that rules out everything from the driveshaft back on the drivetrain. I originally thought flexplate/converter bolts but he said it sounds like its coming from the back too. I read in another post that you were saying something about a heat shield rattling, maybe its that or exhaust just hitting something maybe a hanger came loose. See if you can move the exhaust system around enough to hit anything.
Old Aug 4, 2006 | 02:52 PM
haha check this out i keep my cutout open and it seems to not do it near as bad. What does this mean??
or maybe its just loud enough to make me forget?
Old Aug 4, 2006 | 10:37 PM
JonCR96Z's Avatar
Either you can't hear it over the cutout or it is in the exhaust. How does the gasket look on the cutout? Maybe it is just a leak.
Old Aug 5, 2006 | 10:23 AM
would a leak cause a vibration you think?
Old Aug 5, 2006 | 11:42 AM
JonCR96Z's Avatar
Not sure on that. I thought maybe it just sound like a vibration. Can you feel it?
Old Aug 5, 2006 | 12:25 PM
KILLERARMY's Avatar
Checkout RPM in Garner,NC 919-661-7947 talk to Jay or Ryan.LS1 ride are right up their alley.
Old Aug 7, 2006 | 11:41 AM
Starz T/A 17's Avatar
Agreed, thats where im takin my car when I get it tuned, I know Many people who took their cars their and had nothing but good experiences
Old Aug 7, 2006 | 02:05 PM
  #32
well about RPM....not very impressed when i took my car there. First off tune was horrible. I had to take it back to them 3 different times and still wasnt right. The last time i had them do the tune my tranny felt like the torque converter was lockin and unlockin weird. These guys did the cam install for me right before all this tuning accord l must add. Well end up being they didnt add tranny fluid after losing some during the cam install. RPM guys said that my tranny needed rebuilding. WTF!!!!! So RPM is out of the question
Old Aug 7, 2006 | 04:40 PM
  #33
JonCR96Z's Avatar
I don't know them personally, but I've seen cars that have RPM stickers on them and I'm not impressed. I would go to CarolinaAutoMasters for a tune. I wouldn't take my stuff their for them to work on, but I do my own stuff anyway.
Old Aug 11, 2006 | 08:44 AM
  #34
well it still does it with cutout open....just cant hear it as bad. It seems like it didnt really start doing this vibration until i got to cutout on and had the 3in. pipe(catback) installed. I wonder if i were to just do a custom true dual exhaust using 2.5in. pipe over the axle and forget about the cutout would this be a better setup and eliminate the vibration.
Old Aug 11, 2006 | 11:28 AM
  #35
mg98ta's Avatar
Have you check all your exhaust hangers? It could be you exhaust is actually vibrating around whenever it gets up to a certain rpm from the exhaust pressure. Is any part of the exhaust real close to the body? It could be moving around hitting ur floorboard causing you to feel a vibration. Put the car up on some good jackstands or a lift and start the car up. Have a friend help you and be very careful. Put the car in gear and run it up to the rpm where it usually stars the vibration. You or your friend can then look and see if they can find what is vibrating under ur car. Note, be very careful doing this. Don't just crawl up under the car lay there, look from the side. Also don't rev the car up too high an rpm, free wheelin could cause you to damage something and vibrate the car around on the stands or lift. Let me know if ya find ya problem.
Old Aug 12, 2006 | 06:12 PM
  #36
VENGEANCE's Avatar
really, what cars have you "ran into"? Dont recall ever being embarassed while i had that banner on my windshield......
as a side note, RPM takes in AT LEAST 2 cars a week for tunes where the specific complaint is "jeff creech did something to my car, and claims he doesnt know how to fix it."
Also form personal experience on more than one occasion, Jeff Creech has been, for lack of better words, a complete ******* to me and friends who i brought there.
Horrible businessperson.
