Southern Members A regional forum for all our down South members.
Need some Help With a Clutch set up
Old Dec 22, 2006 | 03:16 PM
EGV00TA's Avatar
Default Need some Help With a Clutch set up in LR
I know this is the wrong section but i still have to ask, has anyone used a RAM billet Steel flywheel with a SPEC 3+ clutch will they even work together I don't want to buy the SPEC and not match up or end up having more problems and i would preffer not to spend another $240 on a spec flywheel since i only have 9000 miles on the RAM. I thought all you had to do was resurface it and good to go but i just want to make sure, thanks for any help with this, laters.
Old Dec 23, 2006 | 02:46 AM
RedHatRdRacer's Avatar
why are you going from a ram to spec?
Old Dec 23, 2006 | 12:40 PM
EGV00TA's Avatar
The RAM HD i had only lasted 9000 miles, no track times and fairly normal driving with only a few launches in the street. do you think the RAM flywheel will fit the SPEC Clutch?
Old Dec 23, 2006 | 07:40 PM
SLowETz's Avatar
If it's a LS1 disk/PP, and an LS1 flywheel.... the answer is........
Yes-
Old Dec 23, 2006 | 08:28 PM
EGV00TA's Avatar
I called the SPEC dealer and they also told me that I would probebly have vibration issues, is this correct or are they just trying to make me spend the extra $250 for a new flywheel??
Old Dec 23, 2006 | 10:08 PM
SLowETz's Avatar
If the pressure plate AND flywheel are true, there should be no issues
Old Dec 23, 2006 | 10:56 PM
EGV00TA's Avatar
thanks for the input
