Southern Members A regional forum for all our down South members.
a little help in central AR
Old Sep 17, 2007 | 06:25 PM
Darbadocious's Avatar
Default a little help in central AR
any of you guys know how to do a proper fender roll and wouldn't mind giving me hand sometime. i'm taking chunks out of my tires.
Old Sep 17, 2007 | 08:00 PM
the_merv's Avatar
Veteran: Air Force
What size Tires..and where you taking chunks out of them..
Old Sep 17, 2007 | 08:42 PM
315's with about an 1.5" drop. it's more like long gashes and its where the tread transitions into the sidewall.
Old Sep 17, 2007 | 10:59 PM
the_merv's Avatar
Veteran: Air Force
Where is it hitting on the Car..inside or outside?
Old Sep 18, 2007 | 02:48 AM
slowandrichws6's Avatar
i have the same problem, 1.5 in drop and 315's, it takes long shavings off of the outside of the tire when it rubs, i took the handle of a floor jack and used it to role it as much as i could but it still rubs when i take corners and bumps.
Old Sep 18, 2007 | 08:39 PM
EGV00TA's Avatar
i used a softball bat to roll the iner fender when i had my T/A take your time.
Old Sep 18, 2007 | 08:46 PM
the_merv's Avatar
Veteran: Air Force
That's like sayin you used a Fryin Pan to kill a fly..lol
What about a Rubber Mallet?
Old Sep 18, 2007 | 09:05 PM
EGV00TA's Avatar
you dont hit the inside of the fender with anything you will **** it up you get some one to get in the car and go forward and in reverse as you place the bat on the tire and roll it in your hands as the car moves don't forget to apply some downward pressure on the bat as it rolls this will roll the inner lip flush and even with out messing up the fender. i'll help you out if you want.
Old Sep 19, 2007 | 05:32 PM
yea man i'd appreciate it. let me know a good time for you.
Old Sep 19, 2007 | 05:53 PM
1cleanbird's Avatar
yup thats exactly what you do. I had to do this on my old 98' sierra with a 4' 6' drop on 20's. Works great! It may rub a tad after ward on big bumps but surely it won't take chunks outta your tires.
Old Sep 19, 2007 | 06:37 PM
the_merv's Avatar
Veteran: Air Force
I see..I see..
Old Sep 20, 2007 | 01:27 AM
i just beat the **** out of mine mabey thats why it still takes little slivers out
Old Sep 20, 2007 | 11:48 AM
EGV00TA's Avatar
PM sent laters.
