Southern Members A regional forum for all our down South members.
What Is Acceleration ?
Old Oct 2, 2007 | 11:03 AM
02402RAMAIR's Avatar
Default What Is Acceleration ?
WHAT IS ACCELERATION ?
A top fuel dragster 500 cubic inch Hemi engine develops more horsepower than the first 4 rows of cars at the Daytona 500.
Under full throttle, a dragster engine consumes 1-1/2 gallons of nitro-methane per second;
a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
A stock Dodge Hemi V8 engine cannot produce enough power to drive the dragster supercharger.
With 3000 CFM of air being rammed in by the supercharger, the fuel mixture is compressed into a near-solid form before ignition.
At full throttle, the cylinders run on the verge of hydraulic lock.
At the stoichiometric 1.7:1 air/fuel mixture for nitro methane the flame front temperature measures 7050 degrees F.
(stoichiometry = Methodology and technology by which quantities of reactants and products in chemical reactions are determined)
Nitro methane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissassociated from atmospheric water vapor by the searing exhaust gases.
Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
Spark plug electrodes are totally consumed during a pass.
After 1/2 way, the engine is dieseling from compression plus the glow of exhaust valves at 1400 degrees F.
The engine can only be shut down by cutting the fuel flow.
If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block and split the block in half.
In order to exceed 300 mph in 4.05 seconds, dragsters must accelerate an average of over 4G's.
In order to reach 200 mph well before half-track, the launch acceleration approaches 8G's.
Dragsters reach over 300 miles per hour before you have complete reading this sentence.
Top fuel engines turn approximately 540 revolution from light to light.
Including the burnout the engine must only survive 900 revolutions under load.
The redline is actually quite high at 9500rpm.
The Bottom Line; Assuming all the equipment is paid off, the crew worked for free, and for once NOTHING BLOWS UP, each run costs an estimated $1000.00 PER SECOND !
The current Top Fuel dragster elapsed time record is 4.0441 seconds for the quarter mile (10/05/03, Tony Schumacher). The top speed record is 333.00 mph. as measured over the last 66' of the run (09/28/03) Doug Kalitta).
To put all of this into Perspective:
You are driving the average $140,000 Lingenfelter "twin-turbo" powered Corvette Z06.
Over a mile up the road, a Top Fuel dragster is staged and ready to launch down a quarter mile strip as you pass.
You have the advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line and past the dragster at an honest 200 mph.
The 'tree' goes green for both of you at that moment. The dragster launches and starts after you.
Within 3.2 seconds the dragster catches and passes you.
He beats you to the finish line, a quarter mile away from where you just passed him.
Think about it, from a standing start, the dragster had spotted you 200 mph and not only caught, but nearly blasted you off the road when he passed you within a mere 1320 foot long race course.
THAT.... IS ACCELERATION !
Old Oct 2, 2007 | 12:10 PM
the_merv's Avatar
Veteran: Air Force
I saw that on another Forum..very interesting..
Old Oct 2, 2007 | 03:30 PM
slowandrichws6's Avatar
spotting you 200 mph and still beating you is pretty impressive
Old Oct 2, 2007 | 03:56 PM
URSLOW2's Avatar
WOW ... some great information Thanks for posting this
Old Oct 2, 2007 | 04:29 PM
HUNTER02SS's Avatar
Why a lingenfelter car??? There are other fast twin turbo corvette's out there??JK! Bad Azz!
Old Oct 2, 2007 | 07:15 PM
99Hawk262's Avatar
Awesome post Kris...I had read that a while back in a Motor Trend Magazine, but it never fails to amaze me.
Old Oct 2, 2007 | 07:32 PM
02SSLE's Avatar
really good info.
Old Oct 2, 2007 | 08:45 PM
I want one
Old Oct 2, 2007 | 08:46 PM
bene's Avatar
Trunion King
Phhhhsssffff. My stock 346 block can beat that. (/one upper).
