This should help..
The Shocks will be here before the end of the week, and the Bar will be here sometime next week.
QA1 REAR COIL OVER SHOCKS
UMI PERFORMANCE DOUBLE-ADJUSTABLE PANHARD BAR, New Item
This is next..
http://www.wolferacecraft.com/detail.aspx?ID=234
The panhard bar is nice but other than allowing you to center the rear under the car isn't going to net you much if any time wise.
As stated, you would have been better off with some replacement front shocks/springs. Either the QA1-R's or Afco's if you can swing them and add the correct front springs to go with them.
I beg to differ about a time gain..getting that ***-end dialed in will help me launch straighter..I'm having some issues with it going to the right out of the Hole.
have you dialed in the pinion angle for the track?
with slicks you should not have any problem hooking at the track
My TA 1.45 60fted on stock suspension
Pinion Angle is set -2* with the UMI Torque Arm I have.
I need to get everything working together..then hopefully it will get out of the hole..
our cars
Not going straight on launch could be several things. What's the air pressure in your drive tires right before a run? You did check it right? Does the rear have an open diff, limited slip or spool? Also, what's the roll out or circumference on your drive tires?
I understand that all the suspension stuff works together to complete the whole car and you have to start some place with it...My only point was your money would have probably been better spent on front shocks/springs at this time.
you need an adjustable torque arm, adjustable front struts (even as "inexpensive" as qa1s as mentioned) and a nice anti-roll bar in the rear suspension. Subframe connectors are mandatory and a 6pt bar will help as well.
I understand you want to defend the purchases you made, but you gotta listen to what works for the "least" amount of money. If you have a big enough converter that'll put you in the 1.4 60' range all day long, even on drag radials. (no, I'm not talking about Nittos or BFGs)
And Bracket racing has no rules, we're talking about heads up racing.
I haven't disconnected the Front Sway Bar on any of these passes..so hopefully that will make a bit of a difference.
Anyone have a link to an Anti-Roll Bar..isn't that just the Rear Sway Bar?
I've used that one in the past and it's a pretty nice piece. Take the front sway bar off as well as the front mounting brackets that are attached to the frame. Once you get a drag bar on the rear you wont really miss the front bar on the street.
