Pros and Cons of the 99 SS
1. 1999-2000 cars switched to 26 lb fuel injectors
2. Cylinder heads and valve covers redesigned to have center bolts instead of perimeter bolts. Other than that, the heads were the same.
3. Redesigned cylinder sleeves that allowed for a small bore, up from .005" in 1998 models.
4. Midyear model change to a cheaper steering wheel audio control button without finger indentations, and cheaper built
5. 1999 cars continued the LS1 intake with EGR provisions
6. 1999 cars continued more restrictive exhaust manifolds and larger cam
7. Only year that Hugger Orange was available (Camaro only)
8. 30th Anniversary Trans Am available with special blue and white paint package and blue clear coated WS6 wheels
9. Switch to larger 16.8 gallon plastic fuel tank to meet new emissions requirements.
10. Gascap tether was shorter and could no longer be used to hang on the gas door when open.
11. Company wide change added black boxes to record up to 5 seconds of data before a crash
12. Rear hatch release was redesigned with stiffer spring that released the hatch better
13. Water temp gauge was redesigned to work basically as a dummy gauge and only show an overheat condition.
14. An oil life monitor was added to all LS1s, thus changing the gauge cluster a little to show the oil life reset swtich
15. 1999-02 cars had a different PCV system with the valve located to the side of the intake manifold
16. Early production 1999 Trans Ams still had the blue outside mirrors, but a midyear change went to the non-tinted ones
17. 1999 there was the color "Medium Blue Metallic" which was available on both the Camaros and Firebirds. Only one year of that color
They really aren't any fundamental differences between the years though other than these.
A trade would only be beneficial if you think your truck is only worth $7000-8000 as that's what that SS is worth.
Regarding a 98-99 vs. a 00-02, the most obvious difference for most people is the wheels, interior color and steering wheel.
The door tag lists 275's as the factory tire size (I was thinking that Z28's came with 255's). Other than that, I don't see anything that stands out.
It's pewter with a M6, t-top, and chrome ZR-1 wheels.
FYI, there were more SS Camaros produced in 02 than Z28s...possibly making the Z28 more of a collector car (beauty is in the eye of the beholder). I don't want to start a huge debate on this topic, just an interesting fact.
Other than that, '99 just features the usual 4th gen flaws like window motors that burn out every few years.
If you want a rare '99, find one with a white interior like this one I found the other day: http://www.autobility.com/vehicle_pa...t-Camaro.shtml
