Thinking of cam
The t-rex shoulldn't be used right now, not in your case. Untill you get gears, fulll exhaust, prefferably heads at the same time, the t-rex is too much on a basically stock f-body. Those things need to be redlined around 7,000 rpm!! You'll need to drop the oil pan and at the very least replace the factory rod bolts with ARP's to handle the rpm. Are you ready to get that hardcore?
I'd go with something in the high 220's to the mid 230's and get a pulley, some gears, tbody and set some money aside for a new clutch and I think you'll be happier.
fuerzaws6
TSP Magic Stick is a big cam that you can run on stock heads.....Do some more research, or call and talk ot some of our sponsors for cams and advice.....
