Special Edition Vehicles Firehawk | SS | WS6 | Berger | Blackbird | Comp T/A
Is it a ws6? help
Old May 3, 2006 | 12:30 AM
curlymojo's Avatar
Default Is it a ws6? help
I think have two ws6's that im looking at, and I need to know if they really are. I only have the VIN #s, and I cant get the RPO codes. I tried carfax and it doesnt know. If anyone could find out using the VIN that would be awesome. Thanks in advance. Here are the vin's \/
2G2FV22PXV2208155
2G2FV22P0T2213295
Old May 3, 2006 | 02:08 AM
1BDWS6's Avatar
Theres no way to tell by VIN numbers.... You need the code from the option list on the drivers door...
Old May 3, 2006 | 04:14 AM
hotrod_bljak's Avatar
Like 1BAWS6 said. There is know way to know by using the vin #. The only way is the code off the drivers door.
Old May 4, 2006 | 09:24 PM
mukyluk's Avatar
email the sellers and ask for a pic of the GM rpo code sitcker
Old May 4, 2006 | 10:27 PM
98 Raptor TA's Avatar
Yeah i believe the code is on the door, but it's also in the glove box, at least on the LT1 WS6's it was, i'm sure the LS1's have it in the glovebox too
Old May 4, 2006 | 11:16 PM
1BDWS6's Avatar
Its only on the door....
Old May 5, 2006 | 04:50 PM
bsf's Avatar
bsf
Even RPO code stickers are easily duplicated. Call ASC.
Old May 5, 2006 | 11:17 PM
curlymojo's Avatar
I tried to get pics but its a dealer and they wont send me pics. Im not important enough i guess.
Old May 6, 2006 | 08:12 AM
99BlackWS6's Avatar
Here are the codes for the first car you listed.
Yes it does show WS6.
VIN 2G2FV22PXV2208155
VEHICLE BUILD
Merchandising Model : 2FV87 -1997 FIREBIRD TRANS AM
Gross Vehicle Weight Rating : 1941 kg (4280 lb) Order Number : RYR021
Build Date : 10/01/1996 Build Plant : 2V2F - STE THERESE ASSEMBLY GM-CANADA
OPTION CODES
AAA - STANDARD EQUIPMENT PROCESSING OPTION AH3 - SEAT ADJUSTER-MANUAL 4 WAY DRIV
AK5 - DRIVER & PASSENGER AIRBAG AQ9 - LEATHER SEATING AREAS INCLUDES: ARTICULATING CUSTOM SEATS W/ ADJUSTABLE LUMBAR SUPPORTS AND ARTICULATING HEADREST
AU0 - REMOTE KEYLESS ENTRY AU3 - POWER DOOR LOCKS
A31 - POWER WINDOWS CC1 - LOCKING HATCH ROOF, REMOVABLE
C49 - DEFOGGER, ELEC REAR WINDOW C60 - AIR CONDITIONING, CUSTOM
DE4 - HATCH ROOF SUNSHADES, REMOVABLE DG7 - MIRRORS, SPORT LH/RH POWER
DL5 - DECAL ROADSIDE SERVICE FE2 - SUSPENSION SYSTEM, HANDLING
FE9 - FEDERAL EMISSION CERTIFICATION GU6 - 3.4 RATIO REAR AXLE
G80 - DIFFERENTIAL, LIMITED SLIP IL2 - TRIM INTERIOR DESIGN
J65 - BRAKES, PWR 4-WHL,DISC FRT & RR KG9 - GENERATOR, 140 AMP
K34 - CRUISE CONTROL, RESUME SPEED LT1 - 5.7 LITER SFI V8 ENGINE
MM6 - TRANSMISSION, 6-SPEED MANUAL MN6 - TRANSMISSION, 6-SPEED MANUAL
NF2 - FEDERAL EMISSIONS - TIER 1 NP5 - STEERING WHEEL, LEATHER WRAPPED W/LEATHER WRAPPED SHIFT ****
N66 - WHEELS, 17" CAST ALUMINUM PBT - TEMP. WHL & TIRE-UPFITTER DLVY
QFK - TIRES, P275/40ZR17 SPEED RATED
R8V - WS6 SHIP THRU ASSIGN
R9Z - POMS EXPEDITE STE - ASM PLT ST. THERESE
T43 - SPOILER, REAR DECK LID
T78 - HEADLAMP CONTROL DELETE
T96 - LAMPS, FOG UA6 - CONTENT THEFT ALARM
UB3 - RALLY GAGES W/TACHOMETER
UK3 - STEERING WHEEL RADIO CONTROLS W/LEATHER APPOINTMENT GROUP
U75 - POWER ANTENNA VK3 - LICENSE PLATE BRACKET, FRONT
VM3 - BUMPER STD IMPACT 5 MPH FRT &RR
V73 - VEHICLE CERTIFICATION U.S.
WS6 - RAM AIR PERFORM.& HANDLING PKG: * RAM AIR INDUCTION SYSTEM * FUNCTIONAL AIR SCOOPS * 5-SPOKE 17" HIGH POLISHED ALUMINUM WHEELS * P275/40ZR17 SPEED RATED TIRES * DUAL OVAL HIGH POLISHED EXHAUST OUTLETS * SPECIFIC TUNED SUSPENSION
WS9 - FORMULA OPTION
W54 - RADIO ETR AM/FM STEREO W/AUTO REVERSE CASSETTE GRAPHIC EQUALIZER INCL. CLOCK, SEEK UP/DOWN REMOTE CD PRE-WIRING MONSOON 500 WATT PEAK POWER W/10 SPEAKER PREMIUM SOUND
Y82 - TRANS AM OPTION
1SA - OPTION GROUP - 1SA 14I - TRIM, DARK PEWTER
142 - TRIM, DARK PEWTER LEATHER 6AB - COMPONENT FRT LH COMPUT SEL SUS
7AB - COMPONENT FRT RH COMPUT SEL SUS 8HS - COMPONENT RR LH COMPUT SEL SUSP
81U - PAINT, BRIGHT RED 9HS - COMPONENT RR RH COMPUT SEL SUSP
Old May 6, 2006 | 08:14 AM
99BlackWS6's Avatar
Here are the codes for the second car.
It too is a WS6.
VIN 2G2FV22P0T2213295
VEHICLE BUILD
Merchandising Model : 2FV87 -1996 FIREBIRD TRANS AM
Gross Vehicle Weight Rating : 1946 kg (4291 lb) Order Number : GCC539
Build Date : 11/16/1995 Build Plant : 2T2F - STE THERESE ASSEMBLY GM-CANADA
OPTION CODES
AAA - STD SAFETY/SECURITY FEATURES: * DRIVER AND PASSENGER AIRBAGS * 4-WHEEL ANTI-LOCK BRAKES - W/ 4 WHEEL POWER DISC BRAKES * PASS-KEY II ANTI-THEFT SYSTEM * REAR 3-POINT SAFETY BELTS AH3 - SEAT ADJUSTER-MANUAL 4 WAY DRIV
AK5 - DRIVER & PASSENGER SIDE AIRBAG
AQ9 - LEATHER SEATING AREAS INCLUDES: ARTICULATING CUSTOM SEATS W/ ADJUSTABLE LUMBAR AND ARTICULATING HEADREST
A31 - POWER WINDOWS
B35 - MATS, CARPET REAR FLOOR
B84 - BODY COLOR BODY SIDE MOLDINGS
FE9 - 50-STATE EMISSIONS
NG5 - 50-STATE EMISSIONS
NP5 - STEERING WHEEL, LEATHER WRAPPED W/LEATHER WRAPPED SHIFT **** N66 - WHEELS, 17" CAST ALUMINUM
R8V - CONTROL-SALES ITEM #71 STE - ASM PLT ST. THERESE
T96 - LAMPS, FOG
UK3 - STEERING WHEEL RADIO CONTROLS WITH LEATHER APPOINTMENT GROUP
U73 - ANTENNA VM3 - BUMPER STD IMPACT 5 MPH FRT &RR
WS6 - RAM AIR PERFORM.& HANDLING PKG: * RAM AIR INDUCTION SYSTEM * FUNCTIONAL AIR SCOOPS * 5-SPOKE 17" ALUMINUM WHEELS * P275/40ZR17 SPEED RATED TIRES * DUAL OVAL EXHAUST OUTLETS * SPECIFIC TUNED SUSPENSION
W55 - RADIO ETR AM/FM STEREO W/COMPACT DISC PLAYER GRAPHIC EQUALIZER INCL. CLOCK, SEEK UP/DOWN 10 SPEAKER SOUND SYSTEM
Y82 - TRANS AM OPTION 1SA - OPTION GROUP - 1SA
12I - TRIM, GRAPHITE 122 - TRIM, GRAPHITE LEATHER
6AB - COMPONENT FRT LH COMPUT SEL SUS 7AB - COMPONENT FRT RH COMPUT SEL SUS
8HS - COMPONENT RR LH COMPUT SEL SUSP 81Q - MOLDING BRIGHT RED
Old May 7, 2006 | 12:42 AM
curlymojo's Avatar
Thank you very much.
Old May 7, 2006 | 08:40 AM
1BDWS6's Avatar
How did you get the codes from the car? I'm just curious, didn't know if there was a way to tell from VIN that I didn't know.
Old May 7, 2006 | 11:20 AM
Black Soul SS's Avatar
x2 how did u do that
Old May 7, 2006 | 12:55 PM
99BlackWS6's Avatar
I work for the General.
I can look up that info and more for most all GM cars and trucks.
Old May 7, 2006 | 04:54 PM
1BDWS6's Avatar
So in other words the sequential number at the end of the VIN is stored somewhere in a computer and tells everything that the car had on it? That's cool.
Old May 7, 2006 | 07:19 PM
99BlackWS6's Avatar
Yes the VIN is used to track build records,selling dealer info, and all warranty work or claims.
Old May 7, 2006 | 09:41 PM
MJK's Avatar
MJK
Hmmmmm..Interesting.
Old May 8, 2006 | 01:11 AM
I couldn't say it any better myself.
Old May 11, 2006 | 09:47 AM
britdog's Avatar
Default Identifying a 1LE
Hi,
I'm looking at a '94 Z28 that I drove last week. I found it odd that it had manual windows, mirrors, door locks, no cruise control. The only option it had was AC. After I got home, I wondered if it might be a special option package car, and that's when I started reading about the 1LE package. Since the car is about 3 hours away, it's tough for me to go look at the door sticker now.
I saw 99BlackW56's posting below in response to a question about identifying a WS6:
I'm hoping you can help me find out the scoop on this car, VIN #2G1FP22P1R2125721
Thank you very much
Old May 11, 2006 | 05:51 PM
boone94's Avatar
thats interesting
