Special Edition Vehicles Firehawk | SS | WS6 | Berger | Blackbird | Comp T/A
1999 Firehawk suspension
Old Jun 20, 2007 | 01:34 AM
Justg's Avatar
Default 1999 Firehawk suspension
I just picked up a 1999 Firehawk. I read the specs. for it on Firehawk.org. It states that the came with an upgraded suspension, but it doesn't say what was upgraded. Any help would be appreicated. G
Old Jun 20, 2007 | 01:27 PM
hawkfiend's Avatar
Firehawks were actually available with three levels of suspension. The sticker on the inside of your passenger door will list the SLP-installed mods on your car.
The three levels were base, Bilstein, or 1LE.
According to my window sticker, the standard Firehawk suspension consisted of a larger front anti-sway bar, and revised rear track. Some SLP advertising mentions "upgraded suspension components", without specifying exactly what they mean by that. From what I've been able to find on the various boards, the base Firehawk suspension is exactly the same as the base suspension on the Camaro SS.
The Bilstein suspension consisted of end links, reinforced stabilizer brackets, SLP progressive rate springs, the 1LE transmission mount, the 1LE trailing arm and panhard bar, and of course the Bilstein shocks. The front and rear sway bars were also different.
The 1LE package was the same as that available on the Camaro SS.
My Firehawk had a 29mm front sway bar, and 19mm back. I upgraded to the 2002-spec bars, namely 32mm front, and 21mm back.
Old Jun 21, 2007 | 04:02 AM
Justg's Avatar
Mine has base suspension. Only options are floor mats, chrome wheels, car cover, and castrol lubes.
Old Jun 24, 2007 | 09:48 PM
99'CajunFirehawk157's Avatar
My SLP build sheets says the same thing: "upgraded suspension components"
other than whats mentioned above, it appears this consist of the "deCarbon" shocks whatever that is...I have been told keep them, & others say change them, so I dunno which way to go, they seem ok and dont leak but.....my suspension is mush in the rear, seems too low too, has in bottom out low, hit a tailpipe on a cross arm low...
Old Jun 30, 2007 | 11:15 AM
Firehawk485's Avatar
I have an 02 Firehawk. Mine has the Bilstein suspension. Look at your springs. I had the SLP blue ones on the rear which sagged bad. I changed these for Eibach pro kit springs and these fixed the sag. The rear now sets about 1" higher than the front which gives a nice forward rake.
Old Jun 30, 2007 | 04:46 PM
SOM02WS6's Avatar
De Carbons are the stock shock on all the cars.........
Old Jul 3, 2007 | 04:17 PM
my1973form's Avatar
I have the same Bilstein suspension from SLP and have noticed since new the rear is lower than the front, some think I have a huge Sub in my trunk, I don't think the spring are saging as the car had 9K on the clock at the time of pic below:
Old Jul 7, 2007 | 11:23 AM
The picture that you posted is exactly the way that my Hawk looked. I haven't taken pictures yet, but the rear is now about 3/4" higher than the front.
Old Jul 8, 2007 | 08:08 AM
my1973form's Avatar
Post it up, I would like to see the difference before and after...
