Special Edition Vehicles Firehawk | SS | WS6 | Berger | Blackbird | Comp T/A
I need some help
Old Sep 7, 2007 | 10:39 AM
bulldog30's Avatar
Default I need some help
my 98 ss is over heating when I am sitting still. I checked the coolant, it is full and circulating so I don't think it is the thermostat or water pump. my fans however only work when I turn on the a/c.
Old Sep 7, 2007 | 02:56 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
My 90 Iroc did the same thing. Turns out one of the fan motors was bad. Got a new one from Autozone and it was good to go
Old Sep 9, 2007 | 06:37 PM
bulldog30's Avatar
but the fans run with the a/c on
Old Sep 10, 2007 | 02:30 PM
98redM6's Avatar
Check the relays for the fans. There are 3 of them located in the fuse boxes under the hood. I have the same problem but mine never reads more than halfway on the temp gauge, so I don't have any problems with bad overheating. I have the a/c turned on all the time anyhow.
Old Sep 10, 2007 | 08:53 PM
bulldog30's Avatar
would the fans run if the relays were bad?
