Special Edition Vehicles Firehawk | SS | WS6 | Berger | Blackbird | Comp T/A
99 SS question
Old Apr 6, 2008 | 12:48 PM
jetlag's Avatar
Default 99 SS question
I'm not too familiar with the options on SS cars...
Was it possible to get a 99 SS with a 3 channel rearend? (no TCS)
Old Apr 6, 2008 | 02:10 PM
SOM02WS6's Avatar
Yes....
Old Apr 8, 2008 | 08:16 PM
Sebring 00's Avatar
Please define in detail a 3 channel rearend (no TCS)
Old Apr 8, 2008 | 08:36 PM
SOM02WS6's Avatar
There is really no need to define, the Traction Control cars have a 4 channel abs system, and the TCS have a three channel rear end.
Old Apr 10, 2008 | 04:50 PM
camarojunky74's Avatar
basically you should be posting in the gears and axle forum, but ill help ya out,
3 channel cars have a toner ring inside the diff which has a sensor mounted on top of the diff housing,
4 channed cars have 2 abs sensors at each end of the axles with toner rings pressed onto the axles,
to convert a 3 ch rear to a 4 ch is easy, you just find a cover for the sensor hole, then gring out a v shap at the back flange at the axle housing ends then just put 4 ch axles in there., your done,
to convert 4 ch to 3 ch takes a lot more work but can be done.
check the stickys in the gears and axles forum
Old Apr 14, 2008 | 05:50 PM
davered00ss's Avatar
Moderator
The answer is yes. You could get it in a 3 channel.
