Strange 12 Bolt/Dana S60 Rearend Group Purchase
Old Feb 5, 2007 | 11:05 AM
  #61
1320 killer's Avatar
Is this still available? heres what I need:
373's
full spool
33 spline
no other options. what is the price?
Old Feb 6, 2007 | 11:21 AM
  #62
Jpr5690's Avatar
THATS NOT COOL, I PAID $315 FOR MY PLATES AND RINGS WHEN I ORDERED THEM A WEEK AGO... I EVEN CALLED AND QUESTIONED IT BUT NOW THEIR $229 ???
Originally Posted by tbyrne
I'm not exactly sure why it takes so long. I know that they build alot of stuff up there. Most of our current orders have been shipping in about 4 weeks.
shocker45:
GP prices -
PRG210-PRGOP8 Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Super Strength posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor at the axles - usually for traction control cars) $2219.99
PRG210-PRGOP-14 Fully assembled and dyno tested rearend (less brakes). Features include 3.150" ID housing ends, 33 spline S/S axles, 1/2" studs,33 spline Super Strength posi unit, choice of 3 channel (center) or 4 channel (axle) ABS ring installed, ABS sensor installed, choice of caliper mounts (1993-'97 or 1998-'02), U-1602 S-series yoke(1350), cross over U-joint, u-bolts, chrome cover and your choice of US Strange standard gear set - 3.42, 3.73, 3.90 or 4.10. (part # for cars with ABS sensor on the top of the pumpkin) $2219.99
gmbbp Options: You will either need to send in your brake backing plates or you can purchase a set to be built into the rear (1998+). If your car has traction control you will either need to send in your backing plates & reluctor rings or purchase them seperately. $229.99
OPRG13 Reluctor Ring Set $69.99
The rears are shipped freight collect so we aren't able to get any firm shipping quotes.
The GP prices were supposed to end on Friday but we will honor it for orders placed through today.
Old Feb 6, 2007 | 11:24 AM
  #63
Jpr5690's Avatar
I Think I Was Priced....
Plates $230
Rings $70
Shipping $15
Old Feb 8, 2007 | 06:27 PM
  #64
Jpr5690's Avatar
Old Feb 9, 2007 | 07:55 AM
  #65
tbyrne's Avatar
Originally Posted by Jpr5690
What do you need to know?
Old Feb 9, 2007 | 07:49 PM
  #66
Jpr5690's Avatar
In Post #62 I Asked If Was I Charged Properly; Because In Post #60 You Make It Sound Like Its Only $230 For Backing Plates And Rings But As I Stated Above, I Was Charged $315 And Am Just Wondering If This Is Correct?
Old Feb 11, 2007 | 11:24 AM
  #67
Jpr5690's Avatar
any reply?
Old Feb 11, 2007 | 01:17 PM
  #68
tbyrne's Avatar
Yes, you replied after we closed on Friday. But I'm taking care of some things today and can give you a reply. Pricing listed in post 60 -
The reluctor rings are located on your axles so those used to have to be sent in with the backing plates if the car had traction control But, the rings are now available seperate so that saves the trouble of pulling the axles and have downtime. The backing plates are $229.99 + $69.99 for the rings and then shipping to get them to Strange.
Hope this helps!
Old Feb 12, 2007 | 06:58 PM
  #69
QuickdomesticRacer's Avatar
Are these prices still current. Are the Dana 60's still available cheaper than the 12 bolts at 20XX.XX??
Thanks.
Old Feb 14, 2007 | 08:26 AM
  #70
dafaic's Avatar
^double that?
Old Feb 19, 2007 | 05:59 PM
  #71
SSinNC's Avatar
^triple that!
Old Feb 19, 2007 | 07:22 PM
  #72
tbyrne's Avatar
You three guys.... and anyone else... order by Friday (2/23) and YOUR IN!
Tom
Old Feb 20, 2007 | 03:32 AM
  #73
BIG BAD BLACKSS's Avatar
Damn damn damn, im gonna have to decide between 9" and S60 faster then i expectedi guess. S60 gonna be abloe to take 7-900RWHP coming of a trans brake dead hooking?
Ive heard due to the bearing placement (no extra bearing on the far end of the pinion gear) that after a couple hard launches they may develop a gear whine? Also, you said the stock posi units are only good up to about 600rwhp, is a detroit locker an option? Anything else that will hold up to the power im looking to put down?
Old Feb 20, 2007 | 04:34 PM
  #74
SSinNC's Avatar
I will be calling you guys tomorrow. Thanks for letting me still get in on this group purchase.
Old Feb 21, 2007 | 11:29 AM
  #75
tbyrne's Avatar
Some info/part numbers have changed since this post went up. This is the current listing -
PRSF05 Strange Dana S60 (will need to purchase a new driveshaft or send yours in to be balanced with the new rearend) $2049.99
Options
R5206 Upgrade to aluminum support cover (not available for the Dana S60) $114.99
True-Track Upgrade to True-Track Posi $79.99
Detroit Upgrade to Detroit Locker Posi $79.99
Driveshafts for Dana S60
U1699 Strange U1699 driveshaft 3"x.083" DOM chrome moly driveshaft with H.D. U-joints $209.99
U1700 Strange U1700 driveshaft 3"x.083" Seamless chrome moly driveshaft with High Imp. U-Joints $329.99
U1702 Strange U1702driveshaft 3"x.083" Seamless DOM chrome moly driveshaft with H.D. U-joints $299.99
Someone called or e-mailed to ask about the GP this morning. The person he talked to wasn't aware of this being opened up until Friday. Everyone here knows now.
Old Feb 21, 2007 | 03:28 PM
  #76
NumberOneSled's Avatar
Difference between true-track and true-track posi? HP rating?
Old Feb 21, 2007 | 03:51 PM
  #77
SSinNC's Avatar
Thanks for the great deal Tbyrne. I ordered my s60 today. Hope fully I will receive it in the next 4 to 6 weeks.
Old Feb 23, 2007 | 10:03 AM
  #78
tbyrne's Avatar
I think you might mean the difference between the Track Loc and True Track? The True Track is the next step up. It's going to be a little more durable but will remain streetable.
Last call!
Old Feb 23, 2007 | 10:41 AM
  #79
"True-Track Upgrade to True-Track Posi $79.99" I ordered my S60 last month and when I saw this posted a few days ago I called to upgrade. Did I just upgrade to the true-track or is it posi?
Old Feb 26, 2007 | 10:11 PM
  #80
Jpr5690's Avatar
hey great news got mine installed today and it sounds like ****!!!!
right out of the shop parking lot all i heard was whineing and grinding along with some clunking
this thing is definately gonna need some work so i guess im going to call strange tommrow morning to see what their going to do
i am pretty god dam pissed off!!!! i just spent $3000 with these guys and i have a broken rear end !!!!!!
