Yank GP
Tom
Order line - 1-877-4-TBYRNE
E-mail - tbyrne@tbyrne.com
SUPERCHARGER DISCOUNTS AVAILABLE!
We're offering 10% off the complete Yank converter line including all of their truck converters -
YANK TRUCK THRUSTER 2600 (4.8, 5.3, 6.0) (278mm, 2600 stall, 2.10 STR)
YANK TRUCK THRUSTER 3000 (4.8, 5.3, 6.0) (278 mm, 3000 stall, 2.21 STR, 98.6% efficiency!) This converter is a modified Truck Thruster 2600. Being so, it shares the stock-like appearance, super-high efficiency, and impressive towing capacity of its lower stall brother. This is the most aggressive converter for the Truck and SUV enthusiast who still wants to maintain their full factory towing capacity. You should expect your 0-60 and 1/4 mile times to drop .5 seconds!
YANK TRUCK THRUSTER 3200 (4.8, 5.3, 6.0) (245mm, 3200 stall, 2.70 STR) This converter is for the truck and SUV "hot rodder". You should expect your 0-60 and 1/4 mile times to drop at least .5 seconds! The Truck Thruster 3200 will allow over 3,200 rpm stall, with only a 1,700 rpm drop between shifts. This converter has a maximum recommended towing capacity of 4,000 lbs. Should you need to tow more, please consider the Truck Thruster 2600/3000 or Truck Stealth 2400.
TRUCK STEALTH 2400 (4.8, 5.3, 6.0) (300mm, 2400 stall, 1.90 STR) Stock appearing converter. Full factory tow capacity. Stock GM converter with pump and stator change. Drops 0-60 acceleration times .2-.3 seconds.
PRO TRUCK 3000, 3200, 3400 (4.8, 5.3, 6.0)(258mm, 2.4 STR) These converters have upgraded clutches to handle high horsepower applications. They have a towing capacity of 7000lbs
YANK TRUCK THRUSTER 2600HD (6.0 and 8.1L with 4L80E trans) (300mm, 2600 stall, 2.0 STR) This converter is a significant step up from stock, but will maintain all the towing capacity intended for this heavy duty class of Trucks.
YANK TRUCK THRUSTER 3200HD (6.0 and 8.1L with 4L80E trans) (265mm, 3200 stall, 2.10 STR) This converter is for the Heavy Duty truck and SUV "hot rodder". It will allow over 3,200 rpm stall, with only a 1,700 rpm drop between shifts. This converter has a maximum recommended towing capacity of 4,000 lbs. Should you need to tow more, please consider the Truck Thruster 2600HD.
More info can be found in the truck section of our website. Orders can be placed online or by calling 1-877-4-TBYRNE (1-877-482-9763).
This offer will be running through Sunday evening (2/29).
Tom
Price Match Plus policy
