Axium Infitinty 7S LED Headlights - LS1 Tech Discount
Old May 31, 2017 | 11:33 PM
apexcustoms's Avatar
Default Axium Infitinty 7S LED Headlights - LS1 Tech Discount
Axium Infinity 7S LED Headlights
Offering 25% to all LS1 Tech Members on our Infinity 7S Headlights
Use Promo Code: LS1TECH25
https://www.apexcustoms.com/shop/Axi...LED-Headlights
PRODUCT DESCRIPTION
When you need better clarity and visual support while driving at night, choose Infinity 7S LED headlights for a clear picture of the road ahead.
When you’re behind the wheel and the dusk or dawn restrict your vision, you need premium headlights that light up the road in front of you so you can drive safely. That’s why we created Axium Lighting Infinity 7S LED Headlights offering better brightness and crystal-clear vision thanks to 5,000 lumens of ultra-bright illumination.
While many LED's on the market look similar, don't be fooled by our cheap competitors. Axium Infinity 7S LED Headlamps are fitted with the most reliable SMD LED chips available on the market. Designed to last and backed by an industry leading 1 year no hassle warranty, Axium 7S headlights offer unrivaled color and light stability designed to withstand light degredation throughout the life of your vehicle.
LED automotive headlights offer superior color and light output while simultaneously reducing energy consumption and heat. Even more impressive, LED lighting will last longer than any tungsten, HID or incandescent competitor.
FAN-LESS DESIGN
With no fan to take up extra space, our Infinity 7S headlights are energy efficient, product low residual heat, and have an operating life that excess 30,000 hours. And because they’re waterproof, shatter-resistant, and easy to install, you’ll want to put them in every vehicle you own.
If you're unsure which bulbs fit your car, check out the Sylvania Bulb Guide.
Product Details
  • High-Powered LED Headlights (5000 Lumens)
  • Fan-Less for Small Installation Space
  • 16 LED for High/Low Beam
  • 8 LED for Single Beam
  • Energy Efficient (Low/High 25 Watt)
  • Low Heat and Energy (-40c to +80c)
  • Waterproof (IP67) and Shatterproof
  • Operating Life (>30,000 Hours)
  • Beam Angle: 360°
