Exedy Hyper Series Twin Plate Clutch & Parker stainless steel zero leak check valves
Here is another old inventory/open box item we are helping another company liquidate. Being sold for less than half the normal selling price.
Exedy Racing Hyper Series Clutch
Stage 4 – Twin Cerametallic
Corvette, Camaro, Firebird, GTO
(LS1/LS6/LS2/LS3/LS7 engines)
PN: GT04XD
Twin disc clutch with ceramic disc material and sprung hub
Part #: GT04XD
For more detailed fitment and other information, download the 2017 Exedy catalog or go to the Exedy web site.
Manufacturer Specs:
All Fitments (PER MANUFACTURER WEB SITE - BE SURE TO CONFIRM FITMENT YOURSELF):
NOTE - WE ARE NOT RESPONSIBLE FOR FITMENT ERRORS
CHEVROLET
PONTIAC
Year Model SubModel Cylinders Liter Aspiration Eng Desg. Fuel Notes
NORMAL SELLING PRICE, ROUGHLY: $ 2050
Asking price: $995 plus shipping if purchased directly (or $1095 on eBay)
Condition:
PN: GT04XD
Part #: GT04XD
Manufacturer Specs:
- Clamp Load 3034 (13500N)
- Disc Diameter (Inches) 8.9
- Disc Diameter (Millimeters) 225
- Kit Contents CT01H, IM14, DT05DA, DT05DB, FT07
- Spline Count 26
- Spline Size (Inches) 1-1/8
- Spline Size (Millimeters) 29
- Torque Capacity (ft/lbs.) 847
CHEVROLET
- Year Model SubModel Cylinders Liter Aspiration Eng Desg. Fuel Notes
- 1998 - 2002 CAMARO Z28 SS V8 5.7 ALL ALL ALL 6Speed Transmission
- 2010 - 2015 CAMARO SS V8 6.2 ALL ALL ALL
- 1997 - 2004 CORVETTE BASE V8 5.7 ALL ALL ALL C5 Chassis; 6Speed Transmission
- 2001 - 2004 CORVETTE Z06 V8 5.7 ALL ALL ALL C5 Chassis; 6Speed Transmission
- 2005 - 2007 CORVETTE BASE V8 6.0 ALL ALL ALL C6 Chassis; 6Speed Transmission
- 2008 - 2013 CORVETTE ALL V8 6.2 ALL ALL ALL C6 Chassis; 6Speed Transmission
PONTIAC
- 1998 - 2002 FIREBIRD FORMULA TRANS AM V8 5.7 ALL ALL ALL 6Speed Transmission
- 2009 - 2009 G8 GXP V8 6.2 ALL ALL ALL 6Speed Transmission
- 2004 - 2004 GTO BASE V8 5.7 ALL ALL ALL 6Speed Transmission
- 2005 - 2006 GTO BASE V8 6.0 ALL ALL ALL 6Speed Transmission
Condition:
- Never used/installed
- Old inventory from promotional projects
- Still in original box
- No warranty - sold as is
__________________
Jason Haines
Product & Service Solutions LLC
www.proservsolutions.com
https://www.facebook.com/proserv/
Jason Haines
We have limited inventory remaining of these zero leak check valves commonly used in turbo systems.
$49.95 each
Contact us directly or can be purchased on eBay here.
Parker C-series stainless steel 5 psi check valve
Manufacturer: Parker Hannifin
Part #: 2F-C2L-5-SS
Often used as zero leak check valves prior to turbochargers so when the engine oil pressure drops below 5 psi no more oil can flow into the turbocharger, reducing smoke on startup.
Manufacturer's description:
Parker C-Series Check Valve, 316 SS body, 1/8" FNPT ends, 5 psig crack pressure, fluorocarbon rubber seal Body Material: 316 Stainless Steel Brand: Parker Instrumentation End 1 Size: 1/8 in. End 1 Type: FNPT End 2 Size: 1/8 in. End 2 Type: FNPT Max. Temperature: 400°F Pressure Rating: 6000 PSIG Product Family: C Series Product Type: Check Valves Seat Material: Fluorocarbon
$49.95 each
Part #: 2F-C2L-5-SS
__________________
Jason Haines
Jason Haines
