Spohn Torque Arm GP
Old Oct 13, 2004 | 09:40 AM
LS1 SPEED INC.'s Avatar
Default Spohn Torque Arm GP
We are running a GP on Spohn Torque arms:
http://www.spohn.net/category.cfm?categoryid=1049
-Part#399 Full Length adjustable Torque arm, mild steel, direct bolt-in, red or black $259.60
-Part#402 Crossmember mountedTorque arm, mild steel, direct bolt-in, red or black $330.00
-Part#405 Crossmember mountedTorque arm, mild steel, direct bolt-in, red or black, FOR USE WITH LONGTUBE HEADERS $330.00
-Add a front driveshaft loop to #402 or #405 for $40
EXTENDED UNTIL THIS FRIDAY 11/5!!!
email me direct tom@ls1speed.com or call us toll free 1888LS1Speed
Tom
Old Oct 13, 2004 | 02:00 PM
BLASTER's Avatar
Any deals on the chromoly ones?
Old Oct 13, 2004 | 02:07 PM
Add $110 for Chrome Moly.
Tom
Old Oct 14, 2004 | 07:09 PM
02 Silver Z's Avatar
Thumbs up
Come on fellas, let`s get this going! I like this piece! How much for a #405, CroMo, poly, w/front and rear DS loops shipped to 48186? (Detroit, MI area)
Old Oct 14, 2004 | 07:18 PM
Z28Maro's Avatar
how much clearance is needed (exhaust wise) for the crossmember mounted torque arms require? i have 3" true x pipe duals. you don't have a driveshaft loop that works with the stock style torque arm?
Old Oct 15, 2004 | 08:24 AM
Add $21 for shipping.
Tom
Old Oct 15, 2004 | 12:45 PM
WARDLAW `02 Z's Avatar
Would there really be THAT much of a weight difference between CroMo and mild steel? Seems on a piece that size it wouldn`t be worth an additional $110.00. It is however a nice looking part.
Old Oct 16, 2004 | 12:56 AM
BLASTER's Avatar
Does the Spohn hang any lower than the stock. My duals are built around the stock TA and that's my only concern. I would love it if had more clearence?
Old Oct 16, 2004 | 03:42 AM
89FormulaLS2's Avatar
Email sent with an application question, but count me in for sure!!
How many orders are we up to?
Old Oct 18, 2004 | 08:53 AM
You may want to go with the stock location unit...
Tom
Old Oct 18, 2004 | 09:10 AM
BLASTER's Avatar
Tom
I understand that....definately the one off the Tranny Tail shaft, there is no way for the tunnel mount one to fit. I was just wondering if I install it, will the overall geometry of the arm be thicker (from top of the tunnel to bottom of the tunnel) than the stock one? Whenever I jack up the car and I don't load the rear suspension the TA rest right atop my DR side pipe - not enough to cause damage just enough to make me uncomfortable. I was wondering if the Spohn would provide a little extra clearence (i.e. thinner or sits higher in the tunnel). Thanks !
Old Oct 18, 2004 | 09:36 AM
How many orders so far?
Old Oct 18, 2004 | 09:51 AM
The tubular torque arm will take up slightlly more space than the stock stamped piece. Without having both sided by side, I cannot tell you exactly.
We have one order in.
Tom
Old Oct 18, 2004 | 05:34 PM
What he said. What`s the weight difference?
Old Oct 19, 2004 | 08:10 AM
Per Spohn:
The weight savings on the 405/402 is 3 lbs. On the full length trans
mounted arm (# 399) it's 4 lbs.
The main advantage to the 4130 is strength. Yes, you save some
weight, but the main advantage is the fact that it's close to twice the
strength.
Tom
Old Oct 19, 2004 | 01:59 PM
camarosandra's Avatar
How much for shipping of #399 to 85001? Thanks
Old Oct 19, 2004 | 02:01 PM
2 in!
$35 shipping.
Old Oct 25, 2004 | 08:51 AM
Question
Any more orders in?
Old Oct 26, 2004 | 09:15 AM
3 confirmed in.
Tom
Old Oct 26, 2004 | 10:46 PM
KAOS's Avatar
running a QMP single turbo kit, any issues you think
