Vinci used part offer
http://www.vincihighperformance.com/...20section.html
VHP 062 CAMSHAFT, 1.8 ROLLER ROCKER KIT, DUAL VALVE SPRING KIT w/titanium retainers HIGH OFFER $950.00
this setup was used for magazine article, under 100 miles on parts
DUR @ .004" 272*/280*
DUR @ .050" 210*/218*
LIFT .551 / .551
OVERLAP 52*
LSA 112*
"ASP-KICKER "
STREET / STRIP CAM - HIGH LIFT
POWER RANGE 1900 TO 6000
TUNING & STALL CONVERTER DESIRED
CRISP THROTTLE RESPONSE - LOADS OF "TORQUE"
" DRIVE - INN " IDLE
rockers, chrome-moly pushrods, guideplates, poly-locks, screw-in-studs
DUAL VALVE SPRING
112lbs @ 1.800
352lbs @ 1.150
will handle .650 lift with .045 coil clearance
retail on this setup is $1417.00
LIFT .551 / .551
OVERLAP 52*
LSA 112*
"ASP-KICKER "
DUAL VALVE SPRING
112lbs @ 1.800
352lbs @ 1.150
Am I looking in the wrong place for it?
http://www.vincihighperformance.com/fbody.html
It still shows $105
It still shows $105
