Camshaft & Valvetrain Group Purchase
Most guys know that all the cams done for our cars sold by the sponsors on here are almost all done by Comp Cams for them.
CAMS:
You can choose any camshaft grind, or custom combination.
For example:
222/222 .566/.566 112/114
224/224 .568/.568 or .581/.581 Lift 112/114 LSA
230/224 .573/.568 111
232/240 .592/.609 112
214/220 .600/.564 115
or any Custom Grind.
We can help you select the right cam for you, or custom design one for you.
$347.95 a cam
VALVE SPRINGS w/TITANIUM RETIANERS:
26918 Ovate Wire Springs $149.95
772 Retainers $148.95
987 Dual Valve Springs $79.95 (Heads need to be cut for these)
776 Retainers $148.95
4712 Spring Seats $26.95
LIFTERS:
Pro Magnum Hydraulic Roller Lifters "Comp R" $189.95
PUSHRODS:
7.400" or 7.350" Hi Tech 5/16 4130 Chromemoly Pushrods $107.95
ROCKER ARMS and SHAFT MOUNT ROCKERS:
1.75:1 or 1.85:1 Pro Magnum Rocker Arms, w/ guide plates, rocekr studs, adjusting nut, and set screws. $435.95
1.7:1 Comp Cams Shaft Mount Aluminum Rocker Arms $799.95
TIMING CHAIN:
Adjustable Billet Timing Chain $159.95
CAMSHAFT KITs:
Base Kit
Camshaft
Hi Tech Chromemoly Pushrods
$605.85
High RPM Kit - for use with high lift cams
Camshaft
Titanium Retainers
Pro Magnum Lifters
$944.75
Race Kit
Chamshaft
26918 Ovate Wire Springs or 987 Dual Springs (-$43)
Titanium Retainers
Pro Magnum Lifters
Pro Magnum Rocker Arm Kit
Timing Chain
$1,540.65
You can contact me by e-mail about this, or call and leave a message at our shop number 607-734-9779. We can order these cams and valvetrain parts at the time of order and we will continue this GP for a few weeks.
Bret
CAMS:
For example:
$347.95 a cam
LIFTERS:
PUSHRODS:
TIMING CHAIN:
CAMSHAFT KITs:
Base Kit
Camshaft
$605.85
Camshaft
Titanium Retainers
Pro Magnum Lifters
$944.75
Race Kit
Chamshaft
Titanium Retainers
Pro Magnum Lifters
Timing Chain
$1,540.65
Bret
