Sponsor Vehicle Projects & Shop Tours See what your LS1TECH Sponsors are working on.
Wheel to Wheel Twin turbo Camaro 11-9-07
Old 11-09-2007, 10:43 AM
427's Avatar
Default Wheel to Wheel Twin turbo Camaro 11-9-07
This is a Camaro with stock truck ex manifolds connecting to a pair of turbo's, and air to air intercooler custom mount in the front. The radiator is also aftermarket, and mounted in the new front fascia support.
Kurt
Attached Thumbnails Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1108tt-turbo0007.jpg   Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1108tt-turbo0008.jpg   Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1108tt-turbo0009.jpg   Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1108tt-turbo0011.jpg   Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1108tt-turbo0013.jpg
427 is offline
Old 11-12-2007, 08:58 AM
427's Avatar
Default Update 11-12-07
A couple newer pics with the fascia off. The mounting of the intercooler and radiator will be done today.
Kurt
Attached Thumbnails Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1111ttcamaro20004.jpg   Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1111ttcamaro20003.jpg   Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1111ttcamaro20002.jpg   Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1111ttcamaro20001.jpg
427 is offline
Old 11-13-2007, 01:32 PM
427's Avatar
Default 11-13-07, turbo mounting
Whitey is making the turbo bracing for the twins, kind of looks like a roll cage for turbo's. It also holds the lower alt in the bracing, although its tough to see in these pics.
Kurt
Attached Thumbnails Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1113ttcamaro30003.jpg   Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1113ttcamaro30002.jpg   Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1113ttcamaro30001.jpg
427 is offline
Old 11-16-2007, 09:12 AM
427's Avatar
Default 11-16-07
The car is on the hoist now getting the finishing touches.
The ex is run back to the trans area, and Whitey is working on waste gate plumbing now. He still needs to run a few water and oil lines, then the customer takes it home to wire and start it! That is when the fun will begin.
Kurt
Attached Thumbnails Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1115ttcamaro40008.jpg   Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1115ttcamaro40006.jpg   Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1115ttcamaro40004.jpg   Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1115ttcamaro40003.jpg   Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1115ttcamaro40002.jpg
427 is offline
Old 12-03-2007, 09:15 AM
427's Avatar
Default 12-3-07 Update
The turbo system is ready to run! You can see the mounting and plumbing of the waste gates. Now the final plumbing and wiring needs to be done to prepare for spring.
Kurt
Attached Thumbnails Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1202ttcamaro50015.jpg   Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1202ttcamaro50014.jpg   Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1202ttcamaro50013.jpg   Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1202ttcamaro50012.jpg   Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1202ttcamaro50010.jpg
427 is offline
Old 12-11-2007, 10:46 AM
427's Avatar
Default 12-11-07
The car is now getting the water and oil lines run for the turbo's. A few more pictures before the front clip is installed.
Kurt
Attached Thumbnails Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1210ttcamaro60006.jpg   Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1210ttcamaro60004.jpg   Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1210ttcamaro60003.jpg   Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1210ttcamaro60002.jpg   Wheel to Wheel Twin turbo Camaro 11-9-07-2007_1210ttcamaro60001.jpg
427 is offline
Quick Reply: Wheel to Wheel Twin turbo Camaro 11-9-07
