Stock Pioneer 12-Disc CD Changer
Old 01-12-2009, 05:59 PM
NonGoggleGuy's Avatar
Default Stock Pioneer 12-Disc CD Changer
I have a 2000 Trans Am. I recently bought a stock 12-disc changer on eBay. It came with two "ear" mounting brackets. As I started to put it into the car, it seems to be not as obvious as I had intended it to be. I don't want to "rig" it into place; I want to do it right. If anyone has the stock disc changer mounted with photos, or any other information, please help me out. Thanks.
Old 01-13-2009, 07:43 AM
Ungrounded Moderator
WhiteBird00's Avatar
The changer mounted to brackets that were welded to the floor pan in cars that had it factory installed. If you're good at welding, the part number is 10276577.
Otherwise, slip a piece of plywood or mdf under the carpet then put your bracket screws through the carpet into the wood and your changer won't go anywhere.
Old 01-13-2009, 08:12 AM
Thanks. I did some research and found the same answer. It's hard to believe that on the entire Internet, I can't find a picture of one of these changers mounted. I arrived at the same conclusion - plywood or a thin piece of aluminum. Thanks again!!
Old 01-13-2009, 11:13 PM
ZeeVert's Avatar
I got the brackets and screwed them down.
There are 2 of the #23 brackets used.
Here's some pictures...
http://s2.photobucket.com/albums/y48...etP1000121.jpg
http://s2.photobucket.com/albums/y48...lodedview2.jpg
Old 01-13-2009, 11:19 PM
PSU 98's Avatar
I also bought the factory bracket and welded it into place. You'll find that the carpet is already scored for the mounting bolt locations as well.
Old 01-15-2009, 05:19 PM
Thanks for all your help, guys!! And thanks for the pictures. I bought a stock mounting kit on eBay and mounted it. It's a lot more self-explanatory when you have the right parts (the CD changer DID NOT come with the right parts). Thanks again.
Quick Reply: Stock Pioneer 12-Disc CD Changer
