Horn on factory alarm not working
Just wondering what to check and where to check to see how to fix this. You know how when you hit the lock button on the key fob twice, the lights flash and the horn sounds, but the horn is not working for some reason. I just put the chrome bolt kit on from Yofab so is there a ground or something that I may not have right or something??? The horn works if you hit it in the car but just not on the key fob.....any ideas???? Thanks!
so is there a way to switch it back? I know the newer vehicles let you select how you want it in the driver info center but i thought the car was just set that way with the horn and lights....does a fuse go to it or something, or would the lights not be flashing if it was a fuse??
