Pioneer avic d3 help
Ok so I already installed my d3 everything is working perfect except that when I turn off the ignition and open door and everything it doesn't turn off Ive tried opening the door closing it again locking the car and nothing help please
Ungrounded Moderator
Have you tried the other door? Do the courtesy lights work the way they should? Sometimes the door switch will get gummed up or out of alignment (or just fail) causing the radio to continue playing until the battery saver feature shuts it down.
The other fairly common possibility is having the constant (battery) and ignition-switched power wires on the head unit reversed.
