Pcm harness problem plz help!!!
put a 98 everything under hood into a 2000 body with 98 engine harness n pcm connecting to 2000 dash harness under glove box and my gauges/cluster will not work...? Can i put a 2000 engine harness on the 98 motor and a 2000 pcm to make gauges work? I basically spent $2000 on this swap now i cant drive my favorite car someone plz help and oh ya the 2000 is non egr i think and the 98 is egr how would i fix that..? only reason being i live in ca which sux lol
By the way all this is six speed swap and i would APPRECIATE all the help i can get maybe even give u $ if ur info solves my problem and by the way my car does drive i drove it home but i need to take it to bar for an inspection thanks again!
1 Post
If I were you I would give Speartech a call, they would be the quickest and best to answer this as they do tons of harness modifications to make things plug & play....
phone: (765) 378-4908
email: speartech@comcast.net
Speartech Fuel Injection Systems
3574 East State Road 236
Anderson, IN 46017
Anderson, IN 46017
On a serious note: If I recall, the clusters are different on the '98s vs. '00-'02. I'm not too positive about the exact pins or wiring differences since I don't have a service manual in front of me.. But do you have the 2000 engine harness and PCM by any chance?
I'm not positive on every little discrepancy between the years, but I believe the BCM only controls the dummy lights on the cluster, the rest is PCM-controlled.
What exactly on the cluster is not working?
You may benefit from PM'ing CalEditor@PCMCalibrators. I do remember a few months back someone had an issue, but it only being the fuel gauge. I'm sure if you explain to him what issues you're having he may be able to set you up with a fix.
As for the EGR, you can find some info and diagrams through the forums. I would help you out instead of suggesting search but I've been up all night at work so my brains a bit fried. You may need some additional components or hoses if you don't currently have them, but everything can be found along with part numbers on the forum.
Good luck
