My Z130BT install (pic heavy)
Old Sep 19, 2011 | 08:54 PM
bill12690's Avatar
Default My Z130BT install (pic heavy)
So here's some pics from the install, double din bezel came from Dennis @ Double D mods.. did the bypass and steering wheel control interface while I was there.
Factory bezel on the left, double din on the right:
Double din bezel with vents/switches/dash plaque:
Z130 in the box:
contents of the box:
almost everything plugged in the back:
the head unit itself:
brackets to mount the head unit:
wiring harness:
closer up
To install the PAC SWI-PS, you have to tap the green wire into the dark blue wire on the factory harness. Since I'm not running an external amp right now, I de-pinned the remote power wire, and re-pinned it to match the dark blue factory wire (so I didn't have to modify the factory wire in any way)
Now, with most of the wiring out of the way, time to mount those brackets to get an idea what I'm working with..
Unfortunately, the brackets were too wide, so I had to cut them on the lines shown here:
cut brackets:
and, I re-installed them on the head unit:
Time to clean up some things inside the dash. With the USB and aux wires, GPS, traffic tuner, antenna, factory and aftermarket harness, along with all the numerous inputs on the Z130, there were a lot of wires to tuck away..
I also moved, IIRC, the retained accessory power module while I was there for some extra room. I may be completely wrong, I honestly don't remember what it is, but I'm talking about the plastic box with the white sticker on it.
Before:
After:
Here's where I ran the USB/aux wires:
And finally, the head unit shoved in there, screwed into the dash. I decided to use the factory screws and holes:
Almost done...
In the next two pictures, excuse the crappy looking dash plaque. I accidentally pried my LE dash plaque off in this process, so it took some of the original silver off with it. Don't worry though, it's all good now
Bezel installed:
Booting up!
Old Sep 19, 2011 | 09:14 PM
Ghostintheshell's Avatar
Awesome!
Old Sep 19, 2011 | 11:15 PM
1badWS6's Avatar
Looks sweet!!! I definitely need to upgrade my flip out to a double din. so much cleaner!
Old Sep 20, 2011 | 12:47 AM
tsench's Avatar
nice leg
Old Sep 20, 2011 | 11:57 AM
bill12690's Avatar
Thanks, clean is what I was going for..
Originally Posted by tsench
nice leg
Thanks? Lol
Old Sep 20, 2011 | 12:17 PM
DOUBLEDMODS's Avatar
Closed ex-Sponsor Account
Great Job on the install!
Thanks again fo the business!
Dennis
Old Sep 20, 2011 | 12:36 PM
BoricuaHec01's Avatar
Formally Simplɘ Jack
That is SICK!!!! I was gonna go single din cause I was trying to avoid taking apart the vents, switches, plaque for the DD bezel but I that just looks awesome, I have to go DD myself. I'm just scared of taking off my plaque. And are the vents and switches easy to take off?
Old Sep 20, 2011 | 04:05 PM
TruBloodTransAm's Avatar
Where did you get those brackets from? Did they come with your head unit?
Old Sep 20, 2011 | 04:14 PM
they come with the install package
we just slipped up and forgot to cut them to size for the Camaro is all
Old Sep 20, 2011 | 08:36 PM
bill12690's Avatar
your plaque should pop right out, it just clips in, along with the switches (which are a little harder to get out, but still easy as cake.. vents arent special anything either, just pull them right out the front, they snap right back in. just be careful, thats all
when I mean my plaque came off, it came un-taped from the original plaque (the piece that clips in)
Dennis
thanks to you too sir
the brackets weren't a problem at all, i just used a 4" grinder with a cutoff wheel and then a die grinder to clean it up
Old Sep 21, 2011 | 06:20 PM
cep39's Avatar
That looks awesome. I am waiting on a pioneer x930bt kit from Double D and I just have a couple of quick questions. Can you explain the re-pinning of the blue wire you did, I am not using an external amp either and I would rather do this than splice the harness. Any problems with the PAC unit programming/functioning? Lastly, how difficult is the install (this will be my first car stereo install) and anything I need to know?
Thanks alot
Old Sep 21, 2011 | 06:53 PM
bill12690's Avatar
Thanks alot
no prob man
here's where the blue wire is located originally (keep in mind this is the aftermarket pigtail, i got mine with the install kit from Dennis)
All I did was kinda wiggle it out, it wasnt terribly hard to remove.
Then, just push it back into this spot (circled in green, in this pic I was one hole off) It should click back into place.
If you do that, it should match the dark blue wire on the factory side, ready to be connected to the green wire on the PAC.
The PAC isnt hard to program, as long as everything is connected right. Being that I had it pinned incorrectly, I had problems at first, fixed it and it was no problem. To me, the hardest part honestly, was getting the head unit mounted in just the right spot, so that it fit into the bezel just right, and still used the factory mounting holes/screws. It wasn't bad though, just took my time with it.
Old Sep 21, 2011 | 08:54 PM
cep39's Avatar
Alright that makes sense and seems very easy. Thanks for the help, the pictures were more than I expected, but greatly appreciated.
Old Sep 21, 2011 | 10:00 PM
Exerstine's Avatar
was that the factory loading screen? lol
Old Sep 22, 2011 | 06:52 AM
Thanks alot
All current Camaro and Firebird orders will be out the door by the end of next week.
We are starting 27 Camaro orders and 18 Firebird orders this morning
Old Sep 22, 2011 | 08:10 AM
bill12690's Avatar
No problem
And no, that wasn't the factory loading screen, lol
Old Sep 22, 2011 | 09:53 PM
bad_408_vert's Avatar
clean install man.
Always liked your car for its bottle set up and now the double din.
Old Sep 23, 2011 | 08:01 AM
bill12690's Avatar
Originally Posted by bad_408_vert
clean install man.
Thanks! Didn't know I had a fan, lol. Bottle isn't in the car right now though, had to take it out when it went to the dealership for warranty work
Old Sep 23, 2011 | 08:16 AM
Ellsworth's Avatar
damn looks so good! how much do one of these run and the bezel, and harness?
Old Sep 23, 2011 | 08:26 AM
139.99 for bezel
12.99 to add install kit of brackets, harness and antenna adapter
12.99 for shipping
total 165.97
Link to order and also the link shows complete radio packages
http://shop.doubledmods.com/Camaro-D...97-02_c603.htm
As always for best deals on some radios call me direct to order
608 568 3011
Dennis
