passenger rear side marker isn't working...
I need help. I've narrowed it down to no power or loose/frayed line because it will come on "sometimes". Bulb is good, the housing is good.
I just need to know where can I follow/lead this from the housing... Does it go to back tail panel? Where does it connect to the fuse panel?
It shouldn't be a fuse because the other side is working and it works sometimes.
Are you 100% sure you are using the correct bulb? I went through this for a while and found that the previous owner installed the wrong bulb. Sometimes it would work sometimes it wouldn't. Best bet is to trace the wiring and test it with a lead, sorry I can't be more help on where to trace the wiring to...
try www.shbox.com , lots of helpful wiring schematics ect on there.
Thanks for the link.
