Monsoon amp question
I have a monsoon amp from a Camaro model 16257161, will this work with the firebird models as well, ive head that they all have the same hook up but im not 100% sure.
Ungrounded Moderator
No, the Camaro and Firebird Monsoon amps are different internally. The connector is the same but the signal output and impedance are different. For example, Camaros use all eight output channels for the different speakers but Firebirds use two channels for each of the sail panel subs and then wire the tweeters directly to the head unit.
