Keyless Entry Upgrade
Old 04-18-2018, 10:10 PM
Kyle_Fbird's Avatar
Default Keyless Entry Upgrade
Hi I have a 97 firebird and was wondering if anyone knows what all i would have to do to get keyless entry on it if it did not come with it originally. I already know i need to change the BCM just wondering if there is anything else to do?
Old 04-19-2018, 06:52 AM
Ungrounded Moderator
WhiteBird00's Avatar
LS1Tech 20 Year Member
Just the BCM and a key fob or two. Here are the instructions for matching the fobs:
1. Turn the ignition key to RUN, then to OFF. This will disarm the content theft-deterrent/alarm system (if equipped).
2. Remove the RADIO fuse. This fuse is located in the main fuse block which is located on the left side of your instrument panel.
3. Turn the ignition key from OFF to RUN three times quickly (within five seconds). The vehicle will respond by locking the doors, unlocking the driver’s door and releasing the hatch. Your transmitter is now ready to match the vehicle. Leave the ignition in RUN.
4. Press and hold the LOCK and UNLOCK buttons on the first transmitter for 15 seconds. The vehicle will respond as in Step 3.
5. Repeat Step 4 for the remaining transmitters.
6. When you have finished matching all of your transmitters, turn the ignition off and replace the RADIO fuse.
7. Check that all transmitters work by pressing the buttons.
