How to wire PAC Pro4 GM11 The NAV/Radio wires where easy.
How to wire PAC Pro4 GM11 The NAV/Radio antennas wires where easy.
07 saab 97x same as trailblazer
Managed to connect a couple wires hopefully correctly.
I assume blaupunkt refers to reverse lights as to brake detect.
I assume blaupunkt refers amp on as amplifier control so far to labling is a toss-up.
I connected the fatter yellow to yellow.
I don’t think I use any speaker wire from HU? or the RCAs
The blaupunkt initial configure settings aren’t listed or recognized by pac4. I'm basically guess a cable labling.
can't find PAC4 orange w/ white stripe
there are 2 black wires from the blaupunkt one fatter, the PAC4 only has one black wire.
update got all the wires connected except for the the extra ground on the Blaupuntk will combine w/ the other ground from blaupunkt the ground to PAC4.
the orange wire I believe is lumination don't think Blau. has this function so I leave unconnected.
the blue coming from back part of the PAC4 I believe is power antenna again unused and covered.
?1.I'm thinkinking all speaker wires from blaupunkt are unconnected?
?2.what is pink W/black stripe wire from blaupunkt labeled FCCD?
?3.what is grey wire from blaupunkt labeled steering wheel control don't see another grey wire to connect to the PAC4
the blaupunkt is a smaller HU than OEM so the front plastic trim piece doesn't fit, it may be easier to buy a install kit than try to fab up a bracket
any tips
any tips
