Removed viper now car won't start
So I was at a parking lot and the car wouldn't start. Key in, no power. So I fully removed the Viper Alarm but now the car won't start still. Again key in no power. Can anyone help.
Ungrounded Moderator
What made you decide that the Viper alarm was the source of the original problem? There are numerous causes for no start situations and I would not assume it was the alarm unless I had other evidence. Do you have power other than for starting (lights, etc.)? Are there any warning lights on? Have you bypassed VATS?
Have you checked all the relays/power/ground under the hood? After that I would make dam sure the battery is good and has good connections at the posts. Side note: If you yanked the alarm I bet the starter kill is still wired in. The wires at the starter kill relay will need wired back together after you solve your first problem.
Starter kill is the Thick yellow wire. It will usually be split into two. Please do not touch the thin Yellow sleeve with the two wires inside. This is airbag. If you don't feel conformable I would advise taking it to someone. A good shop may charge a couple hundred bucks or less.
So I got the car to start. Had my tuner bypass vats in the pcm. The viper may have been good lol.
but now the door locks won't work. They unlock but won't lock
do I still need to wire in the resistor for vats to get my door locks to work? Reason I ask is because the security light is still on in the dash
Regardless of what a tuner may tell you, you can't entirely bypass VATS with programming. VATS prevents starting using two separate methods - disabling the starter relay by not providing ground to the relay coil and disabling the fuel enable signal to the PCM. You can program the PCM to ignore the missing fuel enable signal but you can only enable the starter relay by physically changing the starter relay ground wire.
That being said, if the car starts and runs then VATS is not the source of any other issue other than the security light in the instrument cluster. It is not connected to the door locks in any way although the two circuits are both housed in the BCM. Have you tried locking with the fob and with the switches on each door? That would tell you whether the problem is with the remote, a door switch, the wiring from the switches to the BCM, or possibly the BCM itself. You could also try grounding the red/black wire in the green 6-pin connector at the BCM - that should lock the doors unless the BCM is faulty.
