My Door Locks Are Craaaaaazy!!!!!
I was going to post in lt1 tech but I figure its something that's not just LT1's haveI'm Having problems with my door locks when I hit the lock button they will not lock I have to manually pull the lock. . this is causing my alarm to go crazy because I'm trying to arm the locks and they are not locking. . . what would I need to replace to fix this problem. . . and do you know of any tutorial or diagram to shoe how our locking system works?
Well I don't know how helpful this will be, but here's a schematic for the 93-97 locks:
http://shbox.com/1/pwr_dr_lock_schematic.jpg
I can't find one for 98+, unfortunately. Still searching for the answer to my lock question =P
Do have the last door arm turned on? You can program different functions into the factory alarm. You'd have to check the manual on how to change the functions. You can have it so if you press the lock button it doesn't lock until like 2 seconds after the last door is closed.
Is this both the drivers and the passangers side not locking?
If it is only one side I would bet that the actuator is bad, something is in the way of the arm, or the linkage needs re-adjusting.
