894 fog light bulb, will 893 fit?
Ungrounded Moderator
The only difference between the 893 and 894 is that the 893 has a straight in connector whereas the 894 has a right angle connector. As long as you have enough clearance to plug the harness straight in from the back of the bulb they are completely interchangeable.
I must be missing something. The 893 and 894 bulbs (just like the 880/881 original equipment bulbs that they replace) push into the socket and lock with a 1/4 turn clockwise. There is no need for anything additional to secure them. Do you have broken tabs on yours?
