radar detector ?'s
Ls1tech Bad Ass
the only one i know much about is the solo S2 by escort. its the same exact thing as the passport 8500, except for the cordless aspect.. works with AA batteries so that is the downside... other than that its a pretty badass detector..
Cordless units usually compromise a lot of performance. IMHO the Escort Solo S2 is about the only one out there worth buying. But, if that one is too much $$$ and you need a budget unit, maybe the Whistler 1788 would be OK, as long as you're not a chronic speeder or don't go too far over the limit.
I had the Solo. Got a ticket and the thing never went off. The battery was about a month old. He was using radar. Sold it on ebay and got a V1. Do what Howell said.
Originally Posted by cveklund
Which wire do you use to hard wire it under the dash? I am trying to hardwire it and dont know which wire to use under the steering column in a 01 ta?
thanks,
chris
thanks,
chris
As for detector I am running Escort 8500 with remote cancel switch, works great.
http://i3.photobucket.com/albums/y65...etector002.jpg
http://i3.photobucket.com/albums/y65...install086.jpg
U Can Feed Off Either The Radio Or The Spare Slot In The Fuse Panel Personally Id Use The Radio.. You Can Buy A Harness And Reverse Harness From Bestbuy And Do The Soidering Work Inside Your House Then Just Plug It All Together Thats Basically What I Did Except I Just Knocked It Out The Same Time I Did My Cd Player Install...
Forget the cordless go with the K40 RD850. It is the best one on the market. Besides K40 makes all the radar and laser guns for the police so they know what to block.
Originally Posted by HowellSoccer88
Cordless = Less range = ticket. Buy a V1, hardwire it, and run the wire down the a-pillar. Everyone that gets in my car asks if mine is cordless and it works amazing!
would you be able to post some pics up of how this looks in your car?
thanks
