System Help Needed
System Help Needed
I have not decided if I should just bridge the Olympus to 2 channel to give ALOT of power (more than is rated--COMPS rated at 125 rms/175 peak, but can give 400 rms---all at 4 ohms--with amp bridged, or can run the amp 4 channel at 125 rms a channel) to the comps, or give the extra 2 channels to some rear speakers???? That is a big question, and the question here. I will hardly ever use the dvd feature, mostly just music, but would like to do the setup right.
What is your opinions on RCA's? I know I need to get those still, and probably an alternator.
Also what rca's I need depends on if I am going to do 2 channel or 4 channel off of that amp. The 2000 peak/1000 rms amp has 2 80 amp fuses, but the 4000 peak/2000 rms amp has no exposed fuses.
Setup:
Components: Directed Viper 650.2's
http://www.sounddomain.com/sku/DEI36065
http://www.directeddealers.com/manua...50_2_650_2.pdf
Subs (x2): Elemental 110V.2 (4 Ohm)
http://edesignaudio.com/product.php?...pid=13&cur=USD
HU: JVC KD-AV7010 DVD
http://www.caraudiodeals.com/product...roducts_id=414
CD Changer: JVC CH-X1500 12 Disc CD/MP3 Changer
http://www.sonicelectronix.com/item_2256.html
Amps:
Hifonics XX Hercules:
http://www.sonicelectronix.com/item_4238.html
Hifonics XX Olympus:
http://www.sonicelectronix.com/item_3030.html
Wiring Kit:
Kicker PKD1 1/0 Gauge Dual Amp:
http://www.sonicelectronix.com/item_3935.html
Boxes:
Driver and Passenger Stealths:
http://www.subthump.com/acamarostealth.htm
Rack (do not know if it is going to work yet):
http://www.subthump.com/acamarorack2.htm
Here are some specs on the decoder:
5.1ch Dolby Digital/DTS/2ch MPEG Decoder Built In
Gold-Plated 5.1ch Pre-Output Terminals (Front L/R + Rear L/R + Center + Subwoofer)
Gold-Plated AV Output Terminals
Gold-Plated AV Input Terminals (x 2 pairs)
About the rear speaker:
• : Adjust the center image
so it may be heard only from the center
speaker, only from the left/right front
speakers as a “phantom” center image, or
various combinations of these speakers.
As the number increases, the “phantom”
effect becomes stronger. (Normally select
“4.”) To cancel it, select “OFF.”
here is the guide:
http://books.jvcservice.com/download...5232/36150.pdf
Afraid of 2 things: 1) taking away power to the comps (still would be getting the proper power though if I did do 4x125 at 4 ohms instead of 2x400 at 4 ohms bridged); 2) it not sounding right for straight audio purposes....
Plus I do not know the "TYPE" of speaker (driver, midbass, full range) to put back there...
Setup:
Amps:
Wiring Kit:
Boxes:
here is the guide:
