New Subthump box.. Im guessing it doesnt fit.
Old 08-09-2007, 06:58 PM
Dimitri-'s Avatar
Default New Subthump box.. Im guessing it doesnt fit.
Just got a subthump stealth box and sub from a member.. Im gonna go ahead and guess that it doesnt fit properly? Am I supposed to be bolting something down or is it supposed to go right in..? It seems like the top is too high..
Ill probably end up trying to cut the bottom plastic part of the interior off and trying to make it fit but I dont want to if I dont have to
The last is me holding it up a bit to show the piece that Id end up cutting off
Old 08-09-2007, 07:09 PM
fredmr39's Avatar
eh....that's not a subthump box....??
did they give a reason for selling? ask where they got it from..
Old 08-09-2007, 07:13 PM
Dimitri-'s Avatar
Wow when I look on the subthump site its definitely not as straight compared to the one they have on there.. arr..
Old 08-09-2007, 07:48 PM
smokeum99ta's Avatar
I have one of those boxes sitting in my shed. Took it out years ago but mine slid under the plastic and fit fine. Looks like it needs to go in there farther or might of been homemade and thats why it doesn't fit.
Old 08-09-2007, 08:56 PM
adamz28's Avatar
Definetly NOT home made and not a sub thump. It is an authentic JL stealth box. It should slide right in place. It can be bolted down. I never had to. It stayed in place very nicely. Have you tried lifting up the plastic panel and then sliding it into place?
Old 08-09-2007, 09:18 PM
Dimitri-'s Avatar
Yes I took the whole panel off and tried to get in, to no avail. I will try to mess around with it again tomorrow
Old 08-10-2007, 01:27 AM
YOOFORMULA's Avatar
did you try removing some of the carpeting from behind it? there is also a plastic bottom in that space that could be removed for added clearance.
Old 08-10-2007, 01:39 AM
joelx21's Avatar
Yeah, it looks like a JL stealth box... if that's the case, you got a good deal since JL boxes are more expensive. Well, that's if it winds up fitting.
Old 08-10-2007, 11:34 AM
ws6geo's Avatar
The first series of JL stealth boxes had different model numbers for camaro vs firebird boxes. The rear sheet metal on a camaro vs a TA/Formula is different. Camaros have a little more depth than firebirds. Looks like you have a camaro box. I'd sell it and get the correct box.
Old 08-10-2007, 01:57 PM
KEE AUDIO's Avatar
Take some pics of the box with the plastic off....that's where the trouble lies. Try pushing it in from the bottom and tilt it forward a little as you do. Make sure you have no room behind the enclosure as well. If you take the plastic off and your can slide your hand in beind it...it's not all the way in.
Old 08-10-2007, 02:00 PM
KEE AUDIO's Avatar
One more thing to check before you go cutting stuff!! LOL!! With the plastic off look at the metal tab in the corner that attaches the plastic panel. See if it is obstructing it from going back any further. If so it bends very easily and can be bent up just slightly without much effort.
Old 08-10-2007, 04:00 PM
Dimitri-'s Avatar
gettin beat by rain in NY today! Gonna try tonight or tomorrow in the AM
I hope its not a camaro box that sucks =(
Old 08-10-2007, 04:03 PM
shoemike's Avatar
do you have a cd player mounted in there?
Old 08-10-2007, 05:06 PM
Dimitri-'s Avatar
cd player? uhh.. if you mean the 12d cd changer, I dont have one
Old 08-10-2007, 05:38 PM
Ls1Envy's Avatar
i'll buy the box for my camaro if you want to sell it
Old 08-10-2007, 06:04 PM
presto_z's Avatar
My thought exactly
Old 08-10-2007, 06:39 PM
SSNISTR's Avatar
That is not a JL box....
Old 08-11-2007, 08:29 AM
Dimitri-'s Avatar
It looks like one from a jl site, they say it fits all camaro/firebirds 93-02..
This time I took off the carpet but didnt do shiet.
I just want the thing to fit so I can start upgrading other stuff gd it >.<
Old 08-11-2007, 09:08 AM
KEE AUDIO's Avatar
That is definetly a JL stealth box and the part numbers are the same for the firebird and camaro 93-2002, I checked with JL. Even in the pics of the install it has the exact same bracket in the same location. I also downloaded the intallation instructions and found out something very interesting...you have to remove all the carpet behind the enclosure for it to install...this is step 2 in the instructions.
Here's pics of the JL for comparison:
Old 08-11-2007, 09:19 AM
KEE AUDIO's Avatar
Here are the installation instructions:
Quick Reply: New Subthump box.. Im guessing it doesnt fit.
