radio not working
Old 10-20-2007, 03:50 PM
lightemupnj's Avatar
Default radio not working
my brother just bough his first LS1 and the radio doesnt work I looked at the monsoon amp and it has yellow greese all in the connector. Would that stop it from working? I looked at the wiring goin into the h/u to see if maybe some wires were spliced into but found nothing unusual. The radio turns on makes a pop sound to the speakers but have no sound. BTW everything is factory. Any ideas?
Old 10-20-2007, 03:54 PM
Ungrounded Moderator
WhiteBird00's Avatar
Check the RADIO ACCY fuse (don't just look at it - either test it or replace it) - it's the fuse that powers the Monsoon amp. The grease is dielectric and is there to keep out moisture. It won't cause a problem with the connection.
Old 10-20-2007, 04:24 PM
you wouldnt happen to know where that is would you bc the car didnt come with the manual, and theres no cover on the fuse box under the hood
Old 10-20-2007, 04:32 PM
nevermind I didnt look on the inside one ya I checked it and replaced it same difference, radio turns on but stil just pops the speakers no noise at all.
Old 10-22-2007, 10:53 PM
bump it
Old 12-31-2008, 04:44 PM
williamb81's Avatar
where is the radio acc fuse?????????
Old 12-31-2008, 05:04 PM
In the fuse panel on the left end of the dash.
