Just did an a4 to m6 swap, now have electrical issues
I just had a trans swap on the Z and now the "brake" light stays on on the dash and the day time running lights/ auto headlights don't come on. Is there a wiring issue or something that needs to be plugged back in? The trunk button and remote trunk release doesn't work as well. I want to mess with it after class so any help would be appreciated, thanks.
Ungrounded Moderator
I thought of that but it doesn't fit all the symptoms. If the parking brake switch is grounded out or otherwise engaged, the hatch release should work. Although it could be two separate problems - the brake indicator, DRLs, and automatic headlights could all be caused by the parking brake switch while the hatch release could be a fuse or something.
