Power Antenna Help
Old Sep 5, 2008 | 09:32 PM
Spd-Kilz's Avatar
Default Power Antenna Help
The power antenna on my Firebird has hit the dust. It goes up, but not down. Seeing how I don't really use the radio, I have no need for it.
What is the best (safest) way to disable it? Is there a fuse I can pull? Unplug it?
Thanks!
Old Sep 5, 2008 | 09:34 PM
954mula's Avatar
I unplugged mine. Back behind the spare tire.
Old Sep 5, 2008 | 09:35 PM
*98TransAm*'s Avatar
so you want it to stay down? if so just push it down by hand then unplug the harness of the power antenna which is located by the spare tire.hope that helps
^ha beat me to it
Old Sep 5, 2008 | 09:43 PM
Spd-Kilz's Avatar
Wicked. That's what I'll do. And yeah...I just want it to stay down.
Old Sep 5, 2008 | 09:44 PM
that will do it
Old Sep 6, 2008 | 12:07 PM
wssix99's Avatar
Save the manuals!
Your antenna is fine! Its most likely just gummed up.
You can probably fix the problem on the cheap in a couple of seconds. The paint on the mast peels off and causes it to stick. Often you can soak a rag in mineral spirits, wipe down the mast, and then retract it. Repeat a couple of times and it should work normally for you.
I've noticed that the problem arises more often after exposure to road salts. GM's official factory manual fix (above) will work for a couple of cycles and when it gets too bad to fix, they sell a replacement mast that you can pop in without replacing the motor unit.
Old Nov 26, 2008 | 05:09 PM
JakeLS1's Avatar
im having the same problem. but i dont have a radio anyway because my head-unit is only for my ipod and CDs lol. so im disabling it if i can find the plug yall are talking about
Old Nov 26, 2008 | 05:16 PM
JakeLS1's Avatar
woohoo! it doesnt go up anymore! thank you LS1Tech guys hahaha
Old Nov 26, 2008 | 06:55 PM
Spd-Kilz's Avatar
^^ I did the same thing. For the amount of time I listen to the radio, it wasn't worth the effort to fix it.
It looks goofy up when you're playing a CD anyways.
Old Nov 26, 2008 | 09:28 PM
WhiteBird00's Avatar
Ungrounded Moderator
The cold must be getting to you. How would anyone outside the car know whether you're using the radio or the CD player? So why would it look "goofy" for an antenna to be raised at any time?
Old Nov 26, 2008 | 09:48 PM
Spd-Kilz's Avatar
I was thinking that when I wrote it, but was hoping nobody would catch me looking like a dumbass, and I could get away with being lazy
Let's try this again:
-The car looks goofy when the antenna is up.
-The antenna goes up unnecessarily when playing a CD.
-Therefore, I feel my car looks goofy when I'm playing a CD.
