Street Racing & Kill Stories Basic Technical Questions & Advice
Any suggestions??
Old Apr 27, 2004 | 07:41 PM
lnuxhakr's Avatar
Default Any suggestions??
Not to beat a dead horse but I may be running an '01/'02 Lightning tomorrow. He is pretty much all stock (intake maybe). What are my chances and how should I approach it?
Thanks in advance...
Old Apr 27, 2004 | 08:17 PM
MillaTK's Avatar
You shouldn't have a problem with him at all, as long as he is stock... Just dont screw up your launch too badly...
Old Apr 27, 2004 | 08:19 PM
lnuxhakr's Avatar
i have heard that they are fast. What year did they get the blower?
Old Apr 27, 2004 | 08:22 PM
MillaTK's Avatar
Not too sure about the blower, I thought they all had them? From what i have heard, they usually run low 14s stock... sometimes break into the 13's...
Old Apr 27, 2004 | 08:27 PM
lnuxhakr's Avatar
I thought they got the blower the same year the cobra did...'03 or '04 maybe...but I thought that the older ones were just nat. asp. V8's...
Old Apr 27, 2004 | 08:47 PM
LS2 KLR's Avatar
They got the blower in 99. 01+ they got a little more power as well. MM&FF got a 13.34 in a stock L but high 13s is the norm. My friend was able to pull 13.40s-50s in his somehow.
Old Apr 28, 2004 | 01:55 AM
BigBronco's Avatar
only lightning without a blower is the 351 powered truck back in 94-95 i believe was the years. with a good launch, the race is yours!
Gray
Old Apr 28, 2004 | 07:27 AM
99-LS1-SS's Avatar
STF Veteran
Get a torque converter and you will beat him for sure.
Old Apr 28, 2004 | 10:00 AM
lnuxhakr's Avatar
thanks
Old Apr 28, 2004 | 01:11 PM
King02SS's Avatar
If he's stock like you're thinking you should put the hurting on him. If he's got pulleys and chips and exhaust and intake and drags etc. Then things could get tricky or even nasty for you. If he's stock though don't worry too much just drive like you would any other race. Good luck.
Old Apr 28, 2004 | 01:24 PM
2 FASST SS's Avatar
Agreed, I pulled on a stock one pretty badly...
Old Apr 28, 2004 | 02:07 PM
BigBronco's Avatar
But just watch out for the ones that say "it is only a chip, pulley and tires truck" those are the trouble makers for most ls1 owners that are near stock.
gray
Old Apr 28, 2004 | 02:28 PM
| Powered by Satan |'s Avatar
yeah... 99 was the first year of the blown 5.4's, making 365... dynoing around 340 bc ford underated them like the cobras and other svt products... anyways, those usually ran 13.8's or so stock and the 01-03's came w/ 385 and running 13.4's-13.6's. w/ chip, k&n, pulley(upper and lower), tires... mid 12's... then it gets worse w/ port & polished blower, or even kb on it... but if he is stock... w/ your mods and a good launch... you have the race in the bag
Old Apr 28, 2004 | 02:48 PM
Joegt38's Avatar
Believe it or not but have seen a lightning (bone stock) pull a 13.4. I guy I used to hang with and it was definatly stock. So ya gotta watch it, they can haul *** off the line.
Old Apr 28, 2004 | 03:53 PM
cstchevy's Avatar
the thing is with a lightning, you wouldnt know if they were stock or not unless they told you. the biggest deal is putting the pulleys to increase boost and a chip. Would you ever know, biggest problem for them is traction on the take off. If their running slicks a stock lightning can usually deep into the 12 and with major modifications I have seen 11 and with a forged bottom end and KB supercharger upgrade pull easy 10's. just alittle info.
Old Apr 29, 2004 | 06:58 AM
lnuxhakr's Avatar
thAnks 2 everyone
Old Apr 29, 2004 | 10:16 AM
krazybob's Avatar
yea a stock lightning is no problem, its those modifyed ones you have to look out for. Ive seen mid 12's at the track before, but that was the track, prob be a bit slower on the street. Good Luck.
Old Apr 29, 2004 | 12:34 PM
Skarecrow's Avatar
STF Veteran
Run him to 120mph and you've got the easy win. The lightnings have gobs of horsepower and even more torque, but the aerodynamics of a brick wall.
Old Apr 29, 2004 | 08:46 PM
lnuxhakr's Avatar
thanksto everyone for the advice...looks as though its going to happen the first part of next week..I will update everyone as soon as it does...
