does this sound about right??
Wow thanks for all the input guys, I will definitely follow up with a video of the fox and the bmw. Do you guys think I'll gain anything by making my wot Afr something like 12.8--13.3? I agree its poorly set up but its what I could do with the time/money I had at the time when my stock motor spun some bearings. I've always wanted to go with a least le2 heads but now that winter is almost here and work slows down for me,I'll have to wait for next year or a really good deal.
when you get the tune fixed post up a couple logs and ill try to help you straiten out anything you might have missed
Put a stock cam in that thing you're doing nothing but going backwards with this set up its really full of fail. put a set of heads on that thing or something, you said you're low on funds but built a 383 when a junk yard Lt1 with a CC503 would have been 1/5 the price and beat the **** out of this set up you have now
Stock head CC306 cars have seen 115-116mph so I can't say it's a complete waste... not a max effort setup and certainly not showing it's potential like it would with good heads but compared to stock it's a huge change.
youll deff pick up good power by getting the afr's to mid to high 12's. also back your timing down when you do lean it so you dont get spark knock. once you get the afr's situated then slowly ramp up the timing till you see a small amount of knock then pull 2-3* and leave it there.
Oh and I got my camera mount coming so you guys can watch !!
4.10s and some head work will go a long way towards fixing that combo.
I would ask what RPM are you spinning too, but it won't help because the heads won't let a 383 breathe up high where that cam wants to be anyway.
Should be doing 6200 at minimum... If the valve train is good 6500... I believe that cam keeps putting down power almost to 7K but I would need to look as it's been 10+ years since I had my setup.
Some actual results...
Stock heads and bottom end full bolt on cc306 cam 366 rwhp 368 rwtq
Everyone busts my ***** on these 5.13s… and no one denies that they do not produce a balanced design.
BUT! Pull up along side that car on the street for a punch to 100 and I will flat tell you that 95% of the car driving world is not going to enjoy that run.
Flyby? Fine… If I don't see ya, go ahead on by, I'll be right with ya.
IF I see ya comin'… It's gonna hurt a little. (In truth, its probably gonna hurt quite a bit) It's instant torque. And the 4.10s are basically the same thing, on a lessor and much more practical scale.
