Bolt on ls1 at the track
Thanks man!
TBH I wasn't that happy with how the 60' felt right after the pass-- I'm doing a small rollout before I lay into it because 10 bolt and stock shocks... Then it hooked hard and over loaded the engine some
Pretty sure there's a 7.2 in the car if I wanted to get a little more ornery with the 10 bolt. That or grenade it lol
Around a 3500 quick release, but I don't lay into the throttle until I have good forward and upward movement. Hope that makes sense? The stock shocks don't transfer nearly as well as drag shocks. Kind of a balancing act
Shocks would be a waste on your car unless the stock ones are broken. All you need is a good tire and the right angles in the back lcas/torque arm and that car will dead hook and break the rear end shortly after. Nice job on the new PB
Btw nice job on your latest runs.
Yea probably OK on LCAs, pinion angle would be the only adjustment needed if not already, along with a good tire.
You can hook a car with little weight transfer - stock shocks all around in this one - low 1.5 60 ft
The guy in the right lane is what Hammer would look like with a slick.. SNAP
Yea he's living on the edge with a 10 bolt. My best 60" was a 1.70 with mine. Anytime i tried to get below that it woukd spit a axle out. He did a 1.68 so he's close to total destruction with his.....lol
Man CyberGrey you are HCI and he is just bolt ons. Your on slicks and skinnies he is on DRs. Your in a lighter 3rd gen he is in a 4th gen. You guys are almost running the same times. Must be that Canadian air?
kinda makes me want to get one and do everything that can be done to see if the power is there for 95+ full weight 1/8th mile.
remember folks mph doesn't lie.
you can gear, suspend, shift, and tire a car to better ET's, but you cannot add significant mph from optimizing ET.
It takes power to weight to add MPH.
That guy was a stock to mild LS1 M6.. 13.5's was what he was running that day.
