Difference between LS1 and LT1?
isnt the quickest stock LT1 z28 time like 13.8 in the 1/4? now this is stock meaning no DRs. im sure they could achieve lower with some DR but their trap speed was crappy.
if both cars got good launches and both cars were running good. i think the lt1 could stay ahead till about the 330 mark if that. but after that point the ls1 should roll past fairly easily.
about his traction issues, did LT1s, or camaros, or the 93s or anything about his car have a different suspension setup than my TA? He has had suspension work done, and i think its handling instead of drag, which could give these results, but i figured even a handling package will be as good if not better than stock.
roll races have nothign to do with how they will do down low... my LT1 drags a ls1 nose to nose ( i even put a fender on em) to 50... from there they jsut wave goodbye....
lt1 makes the torque sooner... the LS1 makes more and much flatter line... but comes in a little later.
)Its just you, or your non 01+ LS1. My 01 WS6 would have destroyed my 96Z28 by ALOT!!!!. Like i said the highest torque number on dyno was lower than my highest LS1 vs LT1. Theres just no comparison.
