TA vs Mach 1
Originally Posted by Bob Cosby
Bristol's at ~1500 ft, so you won't see the really good ETs there that you might see on the coast at sea level. 2-4 tenths slower is probably a good guess.
Good run against the Mach1. From what everyone says it's usually a driver's race against one.
Originally Posted by EVILWS6
I have a buddy with a Mach,and they're not like the GT's.They come with a 3.55 gear and a much better motor and from a dig his car is right at the front of my door until we get up to 85 and then my car will start to pull on his.That gear helps them out a good bit.I like them just as much as the 03-04 Cobra's.I love the shaker scoop on 'em.
Originally Posted by That_guy
I think they come with cobra motors just not with the kb in them.
There are several more differences such as the cobras have an iron block and Mach's have an aluminum block. Cobra's comp ratio is 8:1, Mach's is 10:1. Also if I'm not mistaken the heads and cams are different. So other than having the same 281ci displacement the Mach's motor is nothing like a Cobras.
